924 Twin Turbo 5.3 C5 T56 swap!!
Hey guys! I have an 87 924S, I’ve owned it since 06, worked great up until, 2013, and that’s when I made the decision to make this thing wild! Started gathering parts and now finally have enough parts to get started! I’ll be posting here regularly on big updates, I’m making a series of youtube videos, showing the process of this whole build! So stay tuned if you want to follow this journey with us!
YouTube: [You must be registered and logged in to see this link.]
Instagram: [You must be registered and logged in to see this link.]
I’m going to start posting pictures now once I figure out how haha
C4924S- Posts : 53
Re: 924 Twin Turbo 5.3 C5 T56 swap!!
Before the build
C4924S- Posts : 53
C4924S- Posts : 53
Engine is fully rebuilt, with forged pistons and rods, ARP hardware top to bottom.
C4924S- Posts : 53
Already upgraded turbos from twin 5831’s to twin 6266’s haha
C4924S- Posts : 53
Here’s where the juicy stuff comes along! Started chopping ol Pabo!
C4924S- Posts : 53
Part 2 of the chopping! Everything is explained in the videos
C4924S- Posts : 53
Nice, keep posting the pics. My 924 has a LS3 500 plus HP and the Z06 six speed.
kevin924kevin- Posts : 927
Badass! Where can I see that build?
C4924S- Posts : 53
go under the 924 section. I am New Convert . I used the porsche suspension on all 4 corners.
so how much boost you going for? I am considering a turbo or super charger. I have done the spring upgrade cam change. Whole motor was redone. I have researched and i can do up to 8 or so pounds of boost with out issue. This would be good for 100 plus extra HP.
I’m not entirely sure yet, but I’m at the very least running 13
C4924S- Posts : 53
That will add some ponies. Question, are you running the same size turbos for both? In my research i have come to the conclusion that with a twin turbo set up it is beneficial to run one small and one large. This helps in a big way to get rid of the lag. smaller turbo quicker spool. U get the benefits of the turbo much quicker, while the large one is spooling. I watched some turbo tests online with various companies doing the tests. ie hot rod, car caft etc. and they all seem to come to the same conclusion.
Yeah I have looked into that as well, as of now I’m thinking of keeping them same size but not 100% yet haha I only have the one turbo now so I do have time to really think about it
C4924S- Posts : 53
to me it just made sense. get HP down low and let it build as the big guy comes into play.
Haha true yeah! If I can fit it then yeah I may do that
C4924S- Posts : 53
Here’s another update from this weekend I just got done editing!
C4924S- Posts : 53
one idea is to move the shifter to the top of the toque tube. A company called 928 motor sports, I bought my 930 to T56 axle adapters from them. They do conversions for the 928 with the T56. They move the shifter to the top of the TT.
Oh nice! I’ll be sure to check them out! Thanks!
C4924S- Posts : 53
Good luck with the build, been messing with mine off and on for years. Nice to see other crazy people willing to whip out a death wheel and go to town! If you have any questions let me know...
Slpr948- Posts : 55
