Brake/clutch reservoir location question.
I've got my braking system all plumbed in, new flex lines, new hard lines, pedal hooked up etc and ready to connect the reservoirs. Running a dual master manual system w/ Wilwood cable bias adjuster.
I have a Tilton triple-chamber reservoir that I'm planning to mount on the center firewall (engine side) right in front of the heater box. I've notice that my preferred mounting location has the reservoir outlets lower than the inlets on the master cylinders. So I have two questions:
1. Will that work? Does the system supply fluid to the MC solely by gravity, or by suction? Seems to me that for bleeding, the bleeders will still be well below the reservoirs and it should still work...
2. If I need to raise up the reservoirs, how much clearance is there from the top of the firewall to the bottom of the hood? How much above the firewall can the reservoir tops extend?
Thanks.
Thanks.
majormojo- Posts : 82
Re: Brake/clutch reservoir location question.
I use the same thing. Mine is centered directly behind the intake manifold.
Are your reservoir outlets below the MC's? No issues with that setup? If so, that's good news for me.
you shouldnt have any issue as long as the fluid level in the reservoir is the highest point in the system.
majormojo wrote:Are your reservoir outlets below the MC's? No issues with that setup? If so, that's good news for me.
I have been DD the car for 5 years, no problems yet. The only time I get air in the MC is when the brake fluid gets old and starts boiling from the exhaust close the the bottom MC. If the fluid stays fresh, no problems.
Excellent. Thanks for the confirmation. I can go ahead with my planned mount point then.
» clutch reservoir... what are you guys using?
» Air intake LS1
» Removing power brake booster, question
» Air intake LS1
