» Transaxle rebuild
» Hello, Gentlemen.
Yesterday at 7:43 pm by rawr
» alignment specs
clutch reservoir... what are you guys using?
Post  aixgelo78 on Tue Nov 29, 2011 8:42 pm
I am looking for options for the clutch reservoir. I purchase the wilwood reservoir, to match my brake cylinder, but with the mount and adapter, I cannot fit it on top of master cylinder. I would rather keep it close to it rather than farther away. What have you guys used?
TIA
Chris
aixgelo78
Re: clutch reservoir... what are you guys using?
Post  Arthropraxis on Tue Nov 29, 2011 8:49 pm
I used a Tilton three chamber remote reservoir. I have seen that some use a brake MC reservoir from a motorcycle that can be mounted in the space above the clutch MC, in front of the fuse box on the firewall.
Post  aixgelo78 on Tue Nov 29, 2011 9:24 pm
Thanks Anthro.... I purchased one from a kawasaki zx9r. Cant really beat $6. Im not a baller like you with the Tilton Very Happy
Ill report back how it works out.
aixgelo78
Clutch reservoir
Post  fliermike45 on Tue Nov 29, 2011 10:18 pm
I tapped off the forward brake master cylinder reservoir.
Post  944-LT1 on Tue Nov 29, 2011 11:22 pm
I just mounted it upright.
Post  spence on Wed Nov 30, 2011 5:59 am
aixgelo78 wrote:Thanks Anthro.... I purchased one from a kawasaki zx9r. Cant really beat $6. Im not a baller like you with the Tilton Very Happy
I originally bought a motorcycle one too... I laughed when it came though... It was about the size of a shot glass. It looked alot bigger in the pictures on ebay; haha... I ended up buying a Willwood reservoir.
Post  Admin on Wed Nov 30, 2011 7:24 am
Most late model Camaros have a small usable one on them. As does the older Ford rangers.
Post  aixgelo78 on Wed Nov 30, 2011 10:51 am
Adm Very Happy in wrote:Most late model Camaros have a small usable one on them. As does the older Ford rangers.
And to think, I have an older ford ranger. I need to pop the hood and see. Thanks Admin.
aixgelo78
Post  87-944S on Wed Nov 30, 2011 1:24 pm
I gave my GTO one to Skywalker, fits real nice! They are dirt cheap, even new.
Athropraxis, which Tilton did you use? The billet one?
Post  Arthropraxis on Wed Nov 30, 2011 2:15 pm
The one I used is a nylon/plastic with push connectors. They are available with -4AN connectors. It fits well behind the intake manifold.
Post  87-944S on Wed Nov 30, 2011 4:27 pm
Do you have a part number or pic? Iam not thrilled with my 3 Wilwood reservoirs.
Post  Arthropraxis on Wed Nov 30, 2011 5:58 pm
Here it is on Summit. It is mounted where yours are. [You must be registered and logged in to see this link.]
Post  expuppy on Wed Nov 30, 2011 6:23 pm
I went to a Honda shop and purchased a honda brake reservoir from a large motorcycle. Right size and cheap and easy to mount.
expuppy
Post  marc a on Sat Dec 03, 2011 5:36 am
Honda accord, junk yard (including bracket), 5.00 bucks.
marc a
