» Transaxle rebuild
» Tpc LS adapter plate
Removing power brake booster, question
Post  Arthropraxis on Sun Dec 13, 2009 7:19 pm
When taking off the brake booster everything I have read off of the PHB search has you under the dash. I was wondering if you could get to the top bolts easier by taking off the fuse box and coming in through the top? If it is not going to be any easier I don't want to take the fuse box off. I just was looking at it after taking the MC off and it looked like a possibility. Anyone ever try this?
Re: Removing power brake booster, question
Post  Admin on Sun Dec 13, 2009 7:44 pm
You can't get to the bolts by removing the fuse box, but lifting up and to the side will make removal of the clutch assist spring easier....
Post  gt1scca on Sun Dec 13, 2009 8:13 pm
Yep, what he said...
You'll be both places. The pedals are easily removed from outside the car, but everything
must be disconnected from underneath the dash.
Slightly tight with the 944 harness and steering column in the way.
More info here...
Looks like I'll be on my back.
Post  Arthropraxis on Sun Dec 13, 2009 8:33 pm
I saw the picture describing how to take the spring out through the top. That is what gave me the idea. Could I get to the brake pedal easier through the top?
Post  gt1scca on Sun Dec 13, 2009 9:13 pm
Booster bolts, no.
Pedals, YES, definitely.
You need to remove the pedal retainer clip and pushrod retaining clip from underneath first, and the (top - left from the engine compartment) inside bolt is tight, but manageable. Once all is loose, the clutch pedal assembly (with brake pedal shaft) can be pulled out the fuse panel hole. The clutch power assist spring and the rod that locates it may be removed. If you really want to keep the spring in place, adjustments (= less spring tension) should be made at least.
NOTE: I removed the complete pedal assembly through the fuse panel opening, after about 5 minutes of wrenching under the dash.
It's not that difficult, just one more set of steps to overcome.
Thanks.
Post  Arthropraxis on Sun Dec 13, 2009 9:42 pm
I am going to remove the spring based on what I have read. Right now I am just doing everything I can easily with the motor being out. It is a lot easier to do some of this while standing in the engine bay. I will do the dual MC brakes, the clutch MC and AC lines. So more questions will be coming soon.
Post  gt1scca on Sun Dec 13, 2009 9:46 pm
Inspect the firewall around the clutch MC closely while everything is apart. I know of one instance where the metal was cracked but not visible until disassembled.
(Not pushing the plate, just making you aware of the possibility...)
Already planned on doing that.
Post  Arthropraxis on Sun Dec 13, 2009 9:55 pm
Going to get a new clutch MC too.
Success!
Post  Arthropraxis on Sun Dec 20, 2009 6:48 pm
Brake booster is out. What a PITA.
Cancel
Post  fliermike45 on Mon Dec 21, 2009 2:36 am
Cancel
Last edited by fliermike45 on Mon Dec 21, 2009 2:38 am; edited 1 time in total (Reason for editing : Error)
