» Adapter plate
1987 944 Turbo --> LS - Page 7 EmptyToday at 9:35 am by sepheroth86
1987 944 Turbo --> LS - Page 7 EmptyYesterday at 8:32 am by Rob44
1987 944 Turbo --> LS - Page 7 EmptyTue Apr 30, 2024 8:28 am by JW1970
» Parts availability for general maintenance?
1987 944 Turbo --> LS - Page 7 EmptyMon Apr 29, 2024 10:36 pm by zenon
» What coilover spring rates are you running with torsion bar removed?
1987 944 Turbo --> LS - Page 7 EmptyMon Apr 29, 2024 10:24 pm by zenon
1987 944 Turbo --> LS - Page 7 EmptySun Apr 28, 2024 9:38 am by SpeedRacer11
1987 944 Turbo --> LS - Page 7 EmptySun Apr 28, 2024 12:00 am by Raymond-P
1987 944 Turbo --> LS - Page 7 EmptySat Apr 27, 2024 11:09 pm by Raymond-P
» Rear coilover suspension setup
1987 944 Turbo --> LS - Page 7 EmptyFri Apr 26, 2024 3:30 pm by ThomasJoseph315
1987 944 Turbo --> LS - Page 7 EmptyMon Apr 15, 2024 6:59 pm by JW1970
May 2024
6789101112
13141516171819
20212223242526
2728293031
+25
lamrith
964ruf
turbobob924
Jchard944
cazbah362
Rothaus
iamgod
richierich55
jess2suityou
P911P951
Slam
dsrracer
matty89
T951
jpkinerk
944_GASM
murrayg
Hotrodz of Dallas
matt5r951
chrenan
29 posters
Page 7 of 9 Previous  1, 2, 3, 4, 5, 6, 7, 8, 9  Next
1987 944 Turbo --> LS - Page 7 Empty Re: 1987 944 Turbo --> LS
Post  chrenan Wed Sep 05, 2018 9:10 am
turbobob924 wrote:Keep plugging away
Quite a few street drives over the last month, new temp sensor is reading well on the gauge so hopefully the first one was just faulty. Couple more scheduled track days to go this season, first real frost hit the grass this morning, hoping it’s not too early a winter.
chrenan
1987 944 Turbo --> LS - Page 7 Empty lots of great info
Post  964ruf Sun Sep 16, 2018 1:00 pm
thank you for all the great info in your build
964ruf
Post  chrenan Mon Sep 17, 2018 10:08 am
964ruf wrote:thank you for all the great info in your build
Glad it's interesting!
chrenan
Post  chrenan Thu Oct 11, 2018 12:12 pm
A few engine bay pictures, ran a fresh fuel hose to the rail which let me use a hose end to get rid of the blue coupler I had used before, the one blue fitting was bugging my OCD.
chrenan
Post  chrenan Thu Oct 11, 2018 12:13 pm
Well, last track day of the season was Saturday, then we got that snow on Sunday, and then my fresh rims and tires arrived, so I guess I’ll have to wait til spring to try them out!
Had a few wet track days this year which was unfortunate, but did allow me to slow things down and feel out the new engine setup and get used to things. Saturday was cool, but dry! Was able to finally push a bit harder. The car is so fast now, it's really a bizarre sensation, I'm sitting in the same car, the handling and brakes are the same, but the gas pedal is totally different. And it's not like just upping turbo power on the stock engine, the power delivery and character of the engine is so different.
I’ve run a staggered setup of 8” front and 10” rear for years, but as my driving has gotten quicker I feel like I’m lacking some front end grip. Moving to this setup of 10” all round should give me some more front bite and allow me to swap wheels between front and back between track days to even out wear.
Enkei NT03M 18x10 with 265 35 Advan AD08R tires:
chrenan
Post  acorad Thu Oct 11, 2018 2:55 pm
beautiful
Post  lamrith Thu Jan 17, 2019 10:49 pm
chrenan wrote:Well, last track day of the season was Saturday, then we got that snow on Sunday, and then my fresh rims and tires arrived, so I guess I’ll have to wait til spring to try them out!
Thanks for the chat earlier today, been skimming thru your thread all evening!!
So is that the same tire/wheel you had on the rear, just now you have a matching set the front? I will be very interested to hear how it goes next year. I am a big fan of matching all 4 corners for rotation purposes.
lamrith
lamrith
Post  chrenan Thu Jan 17, 2019 11:08 pm
No, totally different rims from my staggered setup Larry. I was running 993 narrow body hollow spokes before this setup.
chrenan
Post  lamrith Fri Jan 18, 2019 1:59 pm
Nice!  Which offset did you got with on the wheels?  Very interested to hear your results and if you have any clearance issues.  They look great.
Go test them, those sleds look like they would be great for floating along in the snow!
lamrith
lamrith
Post  chrenan Fri Jan 18, 2019 7:52 pm
Laughing
The new rims are 18x10 60 offset all round.
chrenan
Post  Rich L. Fri Jan 18, 2019 8:54 pm
Square! I agree. Those Enkei 18s look good on your car. Nice and light too.
I run 17x9 ET55 all around.
Post  docwyte Sat Jan 19, 2019 9:54 am
I ran the exact same thing on track as Rich on my old car
Post  chrenan Tue Feb 26, 2019 1:17 pm
Bit of a winter update. Replaced my front orange indicator lenses with some clear lenses. Also realigned my rear bumper so it sits straight, has been bugging me for years. No pictures of that stuff, sort of boring cosmetic stuff.
Replaced my stock rubber steering rack bushings with some stiffer delrin blue ones:
I also installed a fuel pressure gauge, so that meant reorganizing the gauge layout on the centre console:
I had to lengthen the fuel line going to the rail to account for the sensor fitting (brass fitting with wire coming out of it).
I also upgraded my fuel pump from the stock 944 Turbo unit (blue) to a Bosch 044 pump. For the 044 I ditched the banjo style check valve that comes with the pump and used a -06 Quantum check valve instead, this let me use a free flow AN fitting coming out of the pump.
While I had things apart I replaced the fuel filter/regulator and used better fittings than the black clip on ones. I read the clip on ones may leak, I didn’t have any issues but better safe than sorry.
Also noticed the filter/regulator that came out had a huge dent in it. No idea how I missed that when installing it, I was pretty tired rushing to get it out last spring, but I’m sure I would have noticed that. There’s nothing that could have dented it where it’s mounted, no movement in the mount. It’s possible a stone or marble on the track could have bounced up and hit it (it’s mounted above the half shaft) but seems unlikely.
chrenan
Post  turbobob924 Tue Feb 26, 2019 2:21 pm
Nice
Sent from Topic'it App
turbobob924
turbobob924
http://www.turbo924.com
Post  spence Tue Feb 26, 2019 2:57 pm
I just bought a bosch 044 too. From what I've read they're known to melt stock wiring or cause a huge voltage drop, so be sure to upgrade the wiring to the fuel pump. I used 8guage wiring (probably overkill).
Post  chrenan Wed May 08, 2019 9:10 am
Alright, now time for a more interesting update. The biggest thing you’ll hear from 944 people when you tell them you’re going to LS swap is “you’re going to add too much weight and ruin the balance of the car”.
I had a chance to corner scale my car again, and here’s the results:
In 2016 before the LS2 swap my car weighed 2942 lbs.
In 2019 after the LS2 swap my car weighed 2935 lbs.
Other changes since the “before” 2016 weight include a fibreglass hood (weight savings), Enkei rims instead of 993 Hollow Spokes (weight savings), 265 width front tires instead of 235 front tires (weight gain) and 996 GT3 front calipers and 330mm Cayenne rotors (weight gain). Both measurements were taken with a 1/2 tank of gas. So it’s pretty much a wash, no weight gained!
chrenan
Post  lamrith Wed May 08, 2019 3:15 pm
NICE! Thanks for sharing the data!
lamrith
lamrith
Post  chrenan Tue May 28, 2019 12:40 pm
Finished up a couple track days already this season. Picked up a lot of grip from fresh tires (AD08R) and the wider front rims (265 up from 235). LS2 continues to impress and also gets interesting reactions from folks at the track.
chrenan
Post  chrenan Mon Sep 30, 2019 11:34 am
Great last track day of the season here on Sunday, cool weather and a major snow storm south of us meant a very empty track. Such a fun car, LS2 + 944 = perfection. Had a few transaxle buddies lapping with me as well.
chrenan
Post  chrenan Tue May 05, 2020 12:13 pm
Braaaaaaaaaaaaaaaaaaaaaap...
chrenan
1987 944 Turbo --> LS - Page 7 Empty Lower spoiler
Post  gwistrup Fri May 08, 2020 9:11 pm
Could you please tell me the brand name and where you got your lower chin spoiler? Do you still retain the bat wing with it?
Thanks, Gil
gwistrup
Post  chrenan Sat May 09, 2020 7:21 am
It’s a copy of the old AIR splitter that TPC used to make, I don’t believe Kent sells them anymore. It actually replaces the batwing, it’s quite long underneath and covers the same area under the car that the stock batwing does.
chrenan
Post  gwistrup Sat May 09, 2020 9:53 am
That would be really cool if I could find one like that. Thanks.
gwistrup
Post  jpkinerk Tue Jul 14, 2020 8:07 pm
Wow! What progress from when I last lurked the forum. Looks like it turned out great. Love those wheels and your remote oil filter location. I hadn't thought of attaching the filter plate under the frame rail. I have a lot of plumbing from the BMW hydroboost there, but I might consider that. How exactly did you attach it?
Also, great call on the LS2. That's a great "early" LS choice. What tracks do you frequent? Looks like next summer for me, but then it's on!
JP
jpkinerk
jpkinerk
Post  chrenan Wed Jul 15, 2020 9:16 am
jpkinerk wrote:Wow! What progress from when I last lurked the forum...
Thanks JP!  I've been watching your build, it's coming along great!  I cut a bracket out of aluminium angle and mounted it to the frame rail using threaded holes that were already there (there was nothing mounted there originally, so I'm not sure what they were for).  Then I mounted the remote filter adapter to the bracket.  The frame bolts are big and the angle bracket is thick, so it gives a really solid base for installing and removing the filter.
We got back out on track late last month which was nice.  My local track is Castrol Raceway in Edmonton.  You can just make out the track layout in the picture below, its on the concrete barrier I'm passing.
chrenan
jpkinerk likes this post
