944Hybrids
Welcome to our forum.
» Pacific Raceways near Seattle
Today at 7:26 am by Lemming
» HELP . . . Electrical gremlin
Today at 12:01 am by Rich L.
» Rich's LS powered 944 track car
Yesterday at 8:59 pm by Lemming
» First Time Swap 85 Porsche 944 to LS6
Yesterday at 7:03 pm by kjducati
» Oil and steering cooler options
Yesterday at 6:11 pm by docwyte
» selling conversion parts due to new baby
Yesterday at 4:29 pm by zeusrotty
» Strut brace?
Mon May 14, 2012 5:38 pm by fliermike45
Mon May 14, 2012 1:56 pm by epsylon9mm
» building a 1983 948 on a budget - pointers?
Mon May 14, 2012 7:19 am by Admin
» To " badge or not to badge "
Sun May 13, 2012 5:01 pm by 944-LT1
May 2012
78910111213
14151617181920
21222324252627
28293031
New Project LS1 in Nile Green 1987 944 Turbo
Post  johntorg on Sat Feb 26, 2011 9:28 pm
I have started a second 944 V8 project. The car is a Nile Green 87 944 Turbo, which I have owned for a couple of years. I bought it for the rare color, with a blown engine. I have accumulated some of the conversion parts, including:
2000 Camaro SS LS1
Quicktime Bellhousing
Z06 11 inch Clutch, and Flywheel
C5 Slave Cylinder
Chrysler 11 inch Clutch Disc
TPC LS1 Mounts
TPC Oil Pan
I'm not sure what I'll do for headers yet. The LS1 comes with a nice set of Long Tube Headers which I will look to modify, If that doesn't work, I guess I'll have to have a set fabricated.
[img][You must be registered and logged in to see this image.][/img]
johntorg
Re: New Project LS1 in Nile Green 1987 944 Turbo
Post  robstah on Sat Feb 26, 2011 9:34 pm
Oh you lucky bastid! I want that color so bad. Good luck with the conversion. Will be one awesome car.
Post  Arthropraxis on Sat Feb 26, 2011 9:52 pm
That is a very nice color, motor already removed and no sunroof, you have a good find. I would have liked to be able to find something other than red.
Post  johntorg on Sat Feb 26, 2011 10:05 pm
Thanks, guys. I'm just waiting for the oil pan from TPC to get started. The LS1 engine is from a drag car and has nitrous. Do I dare?
johntorg
Post  Arthropraxis on Sat Feb 26, 2011 10:27 pm
Run it till it blows.
Post  Admin on Sat Feb 26, 2011 11:13 pm
Your pan shows to be delivered on the 22nd. Did you get it?
Post  docwyte on Sat Feb 26, 2011 11:19 pm
Never seen one in that color before. Wish I had a no sunroof car...
Post  johntorg on Sat Feb 26, 2011 11:31 pm
I received 1 box, which I haven't opened it didn't look big enough for the pan, so I assumed it was the mounts. Was the Pan shipped separately? I'll open the box tomorrow and check.
johntorg
Post  Admin on Sun Feb 27, 2011 9:05 am
Should have everything in one box. The box should be 24"x18"x9" or something close to it. Mounts and oil pan should both be in there.
Post  johntorg on Sun Feb 27, 2011 9:09 am
Thanks, I'm sure its there, just stupidity on my part. Do you still sell the crossmember for in front of the radiator?
johntorg
Post  Admin on Sun Feb 27, 2011 9:22 am
Yes, I do. I'll list it on the store front tonight. I forgot to add that item........ Shocked
Pulled LS1 Engine
Post  johntorg on Fri Mar 18, 2011 6:01 am
Removed the engine from the 2000 Camaro SS yesterday. No surprises so far, just some badly leaking valve cover gaskets a missing idle air control valve and a bad hose in the PCV circuit. So Far, so good.
johntorg
You have caught the bug!
Post  968gene on Sun Mar 27, 2011 4:57 pm
wow John you have really jumped into the 944V8 deep end. I can't wait to see the green car in person. Gene
968gene
