1987 944 Turbo --> LS
+25
lamrith
964ruf
turbobob924
Jchard944
cazbah362
Rothaus
iamgod
richierich55
jess2suityou
P911P951
Slam
dsrracer
matty89
T951
jpkinerk
944_GASM
murrayg
Hotrodz of Dallas
matt5r951
chrenan
29 posters
Page 2 of 9
Page 2 of 9 • 1, 2, 3, 4, 5, 6, 7, 8, 9
Re: 1987 944 Turbo --> LS
Did some test fitting of the new clutch master cylinder, just fits!
What orientation are guys using for the high pressure line coming out of the end of the master cylinder? Should I be aiming the 90 degree fitting down on an angle or straight across? I'll wait til I have the hydroboost setup test fitted to finalize, just curious at this point.
Old vs New
Tight Fit
Old vs New
Tight Fit
chrenan- Posts : 203
The inlet fitting will need to point up and back slightly to clear the HB. The outlet fitting is probably ok the way you have it. I usually turn mine in the opposite direction.
Bang in the inner fender well just a little & flip it over so the inlet is on the out side, way better if your using the hydro boost set up.
T951- Posts : 10
you cant use the stock porsche master ? for the clutch ?
matty89- Posts : 62
matty89 wrote:you cant use the stock porsche master ? for the clutch ?
Stock master cylinder won't move enough fluid to operate the GM slave cylinder. Texas Performance Concepts has a master cylinder spec'd to work with the GM slave. It will bolt up to the stock location.
T951 wrote:Bang in the inner fender well just a little & flip it over so the inlet is on the out side, way better if your using the hydro boost set up.
I've done them both ways. It will fit either way. I prefer not beating the fender well, but that's just me.
Found a silicone cap to plug the extra port on the coolant expansion tank. The normally aspirated tank only has the one port, but I can save a few dollars by reusing my turbo version for now and blocking this port off.
Also mounted the starter.
Test mounted the coils where the intercooler used to live. This keeps them out of the heat and frees up some space, although I'll have to buy or make custom long plug wires. Was as able to mount this way using existing holes in the car, nothing new was drilled, which is always my preference.
Installed the flywheel. Was going to do the bellhousing too and realized I don't have bellhousing bolts. Old age must be setting in.
Just out of curiosity, why did you bolt the knock sensor in that location instead of the stock location?chrenan wrote:Found a silicone cap to plug the extra port on the coolant expansion tank. The normally aspirated tank only has the one port, but I can save a few dollars by reusing my turbo version for now and blocking this port off.
You'd have to ask Turn Key Engine Supply who built the motor for the original purchaser (not me). I'm not really sure why they did that. They put rubber plugs over the openings for the sensors in valley cover. I'm not really sure what the thinking was. Maybe it's easier for the custom harness they supply with the engine?
chrenan wrote:You'd have to ask Turn Key Engine Supply who built the motor for the original purchaser (not me). I'm not really sure why they did that. They put rubber plugs over the openings for the sensors in valley cover. I'm not really sure what the thinking was. Maybe it's easier for the custom harness they supply with the engine?
What engine are you using? And what ECU? Depending on your engine and ecu, those may not be the correct knock sensors.
that style knock sensor is used on the 58x/4x crank/cam trigger wheels that all go with the gen 4 ecm.
It's a crate engine/harness/computer package:
Similar to this spec but optioned with an aluminum block and LS1 intake:
chrenan wrote:2008 build by Turn Key Engine Supply, a 5.3 litre aluminum block with an LS1 intake and their standalone harness (5-wire hookup) and MEFI-5a ECM.
chrenan wrote:It's a crate engine/harness/computer package:chrenan wrote:2008 build by Turn Key Engine Supply, a 5.3 litre aluminum block with an LS1 intake and their standalone harness (5-wire hookup) and MEFI-5a ECM.
Cool. You should be good to go then. I only asked because I've seen people trying to convert and mixing parts that didn't work together.
Hotrodz of Dallas wrote:Cool. You should be good to go then. I only asked because I've seen people trying to convert and mixing parts that didn't work together.
Always appreciate the extra eyes on the work, thanks!
sharkey wrote:that style knock sensor is used on the 58x/4x crank/cam trigger wheels that all go with the gen 4 ecm.
There are definitely some oddities with how they put together the engine. Gen 4 location for the knock sensors, but Gen 3 location for the cam sensor through the top of the block at the back of the valley cover. Also has a Gen 3 valley cover. MAP only no MAF, cable throttle. It all connects nicely to the stand alone harness that came with the engine, but I do wonder why some things are the way they are.
im going to retry my stock porsche clutch master ... but im getting a low grab and feeling .... pretty sure there is no air .. i drove the car for a week ... just it has to play its 1 " from the floor and that is ur play.. i tried ajusting the pedal and nothing would change it ... i guess im back to the drawning board loll you have a part number ? for the clutch master ?
matty89- Posts : 62
I'm having the same issue with my stock MC. I believe I'll change to 7/8 and not 13/16 dia. I think this one is 7/8 isn't it? Thanks.
dsrracer- Posts : 66
It's a CNC 7/8, don't have the part number handy but I can see if there's one on it the next time I'm working on the car.
Not much to update, had some parts come in so I'm sorting and figuring out some things. Figured I'd install the water pump so I feel like I accomplished something.
Fitted the clutch slave adapter that goes between the torque tube and the engine bell housing:
Did some work on the engine, installed the bellhousing without the clutch so I can confirm the drive shaft has proper insertion or if it needs adjusting before installing the clutch. Also installed the mounts and cross member and placed it on rollers to be ready to go under the car for install.
Some shots of the clearance to the pan, they make it look a little tighter than it actually is, it's a tough angle for an Iphone.
The crossmember to pan isn't really the close fit. It's the steering rack to pan that's close. You usually have to bend the metal lines on the rack for more clearance.
» 1987 944 turbo look LS3 swap
» New Project LS1 in Nile Green 1987 944 Turbo
» 1/3 Life Crisis... 1987 944 turbo ls1 conversion
Page 2 of 9
