Bump steer
Bump steer
I've made a few posts but only recently do I have the parts to really make progress. I want to put the engine in next week and have started thinking forward. I know the 1/2 spacers affect steering geometry but I don't know how much. As a street conversion has anyone felt the need to correct the geometry to avoid the bump steer change? Is it important or kinda trivial?
dsrracer- Posts : 66
Re: Bump steer
when i put my car together i cycled the suspension with the 1/2" spacers and bump steer was minimal. in the 1200km ive put on my swap i havent thought about bump steer at all.
Re: Bump steer
Thanks for the input. It doesn't sound like this is an issue.
Probably like any project, the things you worry about turn out to be no problem at all and the things you don't worry about end up taking a huge amount of time.
Re: Bump steer
i should add, that my 1200km has been shaking the car down and some spirited street driving. on the race track it may be a completely different situation.
Re: Bump steer
i get shake at 140kmh with 3k rpm and at 3k rpm 50kmh also.... if im on a highway and get in truck marks it goes crazy ..sharkey wrote:i should add, that my 1200km has been shaking the car down and some spirited street driving. on the race track it may be a completely different situation.
matt889- Posts : 214
Re: Bump steer
check your ball joints for play, along with every bushing, tie rod ends, steering rack, etc. these cars are between 25 and 33 years old, cars dont get better with age.
when i bought my car it drove smooth and good, no vibrations or anything. when i tore it down for the swap everything was tight and felt good. after i was done the swap i had a steering wheel vibration at 100 km/h. i went through checking everything was tight and trying to figure out what i did wrong, couldnt find a thing. i finally found it when i checked the ball joints with the jack under the control arm, they were loose. i chalked it up to be the difference in the ride height (i put in some drop springs, but with my swap the motor is lighter than stock so i ended up pretty close to the same ride height) and dropping the cradle put the ball joints into a more worn spot. rebuilt them and no more shaking.
» bump steer, manual rack tie rod end adapter (come in xschop)
» Hey Hey! Adjustable Bump-Steer!
» C-5 Bell Housing
» C-5 Bell Housing
