SBC Conversion Valve Cover Clearance
Hello there everyone. My conversion is coming along nicely. I have the C5 2piece bellhousing adapter combo, no spacer plate and Sanderson headers. I also have the motor mounts from TexasPerformanceConcepts. I have the motor installed and my crossmember in. My trouble is the valve cover clearance by the master cylinder. Is there a different M/C I need?
mred2nice- Posts : 79
Re: SBC Conversion Valve Cover Clearance
I can't tell from the picture, is your factory brake booster still there? Supposedly it wont fit on an ls swapped 944. I removed mine and installed an adaptor from renegade hybrids. I still had to shave a little bit of material off the m/c just to gain a little more clearance. My valve cover fit fine, but the rear coil pack is pretty close. Glad I didn't have to relocate it like some other have had to do though!
lsporsche- Posts : 72
Depending on what valve covers you are using, you might be able to cut and weld the corner of the cover to clear the M/C.
» 87 S with 2004 GTO LS1
» 1997 C5 LS1 5.7 806 Valve Covers Driver side Needs mod
» Mustang hydroboost valve cover clearance
