Front Shocks?
Front Shocks?
I am looking to place an order for some front shocks. I was looking to place an order for some konis similar to the ones pictured below. My car is an 1983 944. Just want to make sure I place an order for the correct piece. If anyone has any other options or success with a different brand let me know I am open ears.
Jchard944- Posts : 96
Re: Front Shocks?
The Koni sport shocks I use are inserts. If you haven't cut your housings for inserts, and don't want to, be sure you don't get just the insert part. On the other hand, inserts are cheap and cutting your existing housings to do the inserts isn't too hard.
Re: Front Shocks?
Rich, I just watched several videos on cutting the housings and putting in the inserts. Was not aware you could even do that. Definitely think I will go that route. Do you have the part number of the inserts you used for the fronts? Looking to place an order here soon.
Also what springs did you use for the front? (brand, lb., etc.) Ill be going with a iron block 5.3 and some other forced induction mods added to the front. Plan is to get the car on scales here within next month just trying to get jump start if I can.
Thanks for the help
Thanks for the help
Re: Front Shocks?
My car was a SPEC 944 racer in it's previous life. A local shop installed the Koni / Ground Control suspension package w/ 450 lb front springs. When I replaced the shocks recently, I got these:
http://www.paragon-products.com/Koni-Sport-Strut-Porsche-944-968-p/8641-1414sport.htm
» New convert under way
» Lots of brand new swap parts. Parting out my whole car.
» best set of shocks for street car
Today at 8:08 am by gwistrup
Yesterday at 11:12 am by Nath1142
Mon Apr 22, 2024 8:22 pm by lowform
Mon Apr 22, 2024 8:12 pm by lowform
Tue Apr 09, 2024 2:54 am by lowform
