» New 944 widebody & aero
» Oil Pan question
» 83' Porsche 944 LM7 Build
Alot of goodies for sell!AOR LSD trans,LS6 intake, strut bar,sway bars,coilovers,wheel adapters and more!
Post  DJ. on Thu Nov 21, 2013 9:39 pm
Hi Guys,
I've put my project on hold and I am selling some of my parts.
-1989 Porsche 944 turbo S LSD transmission / transaxle code AOR with oil cooler. The unit has 133 782Km/83 128 miles from a car that was hit in the front SOLD
-4 x custom machined 5x130 to 5x114 25mm adapters very tight clearances !Hub centric and wheel centric,14mm 10.9 grade studs (see picture with the Enkei rpf1's 15.6lbs each wheel 17x9!) 200$  Practically new just tried wheels on then project took a halt.
-Used Weltmeister 22mm rear bar with adjustable end links 200$
-Front strut brace 150$ used
-Used Big red brake kit (calipers, SS braided lines front and rear, adapter and rotors) Used SOLD
-Momo steering wheel hub 40$
-Momo Corse seats, mint! with side rails and 944 sliding rails SOLD
-Bilstein cup coilovers front and rear (without camber plates+ coilovers are dirty in the pictures) SOLD
-KMR Pro series Camber plates  200$ for the pair used.
-87 turbo spindles with Billet hubs 450$ Pair.
-LS6 intake manifold (billet rails no longer available)400$  I have the stock rail for 20$
DJ.
Re: Alot of goodies for sell!AOR LSD trans,LS6 intake, strut bar,sway bars,coilovers,wheel adapters and more!
Post  DJ. on Thu Nov 21, 2013 9:41 pm
DJ.
Post  DJ. on Thu Nov 21, 2013 9:49 pm
DJ.
Post  Techno Duck on Thu Nov 21, 2013 11:18 pm
Location?
shocks
Post  kevin924kevin on Fri Nov 22, 2013 7:37 am
How old are the shocks and what spring wieght r they. Do u still have them?
Post  DJ. on Fri Nov 22, 2013 10:33 am
Everything is located in Ottawa, Canada.
coilovers just sold this morning.
DJ.
Post  admiralkhole on Sat Nov 23, 2013 4:24 pm
Will you do $40 shipped for the steering wheel hub adapter?
admiralkhole
Post  CBRE on Mon Nov 25, 2013 8:10 am
Ill take the four wheel adapters.
email me at [You must be registered and logged in to see this link.] thanks!
CBRE
Post  DJ. on Mon Nov 25, 2013 11:22 am
Updated list and no I wont take 40$ for the hub shipped.
DJ.
Post  DJ. on Thu Nov 28, 2013 12:03 pm
Big reds sold!
DJ.
