LS 430 Big Brake Swap
I have been reading about the LS 430 big brake swap. I understand what you do on the front system but what about the rear brakes. What do you do there. Do you use the LS 430 rear brake calipers and Boxter rotors? thanks
TampaPete- Posts : 5
Re: LS 430 Big Brake Swap
TampaPete wrote:I have been reading about the LS 430 big brake swap. I understand what you do on the front system but what about the rear brakes. What do you do there. Do you use the LS 430 rear brake calipers and Boxter rotors? thanks
The general consensus is throwing some 951 or rx7 turbo front calipers on the back. There is a long thread on here that gives more details. Happy hunting
drive135mph- Posts : 9
Year Range
Hey guys I was curious about what years range for fitting 951 and rx7 front calipers on the rear
Punisher948- Posts : 39
Punisher948 wrote:Hey guys I was curious about what years range for fitting 951 and rx7 front calipers on the rear
I think people are using the FD RX7 front calipers (93-02).
crowstyle- Posts : 28
you can also use the 4 piston fc rx7 calipers. ive got a set off a turbo 2 rx7 on the back of my 944.
» LS430 Big Brake Swap
» RX7 Rear Brake Swap adapters
» What's the largest brake swap that will fit under 15" phone dials?
