Broken clutch disc
Broken clutch disc
Pulled my clutch out due to issues I was having with shifting gears. Initially I thought it would be a bad HTOB but I found these cracks and chipped section on the clutch disc. The broken piece was loose inside of the pressure plate when I pulled it out, not sure if it just snapped off during removal or was stuck in there from before. There are also a couple of hairline cracks around some of the other springs, similar to where the broken section failed. Do you think this would prevent disengagement of the clutch? The pressure plate and HTOB look fine so I'm still trying to figure out what was causing the problem.
948inVA- Posts : 224
Re: Broken clutch disc
seen that many times in different cars. the piece that is broken off the hub ands up jamming between the clutch disc and the pressure plate (or if it were on the other side, the flywheel bolts and the disc) and because of it the clutch disc never stops turning. it acts like a bad htob, however the key difference would be that with this sort of failure the clutch pedal would feel fine. when the htob goes you end up with a spongy pedal, or lose the clutch pedal.
Yep, describes the symptoms pretty much spot on. I'm thinking I'll just get the LS7 clutch kit to replace this. Anyone have a source/part # for the conversion disc that works with the LS7 setup?
Uhg, that sucks. What clutch disc is that that failed? OEM or aftermarket?
It's the TPC 11" conversion disc.
» Source for LS7 clutch disc?
» I need a used clutch disc from a 944
» Clutch disc for LS7 FW/PP assembly
