clutch disc EmptyYesterday at 11:51 am by geegeesbits@gmail.com
clutch disc EmptyMon Jan 27, 2020 2:27 pm by Porsche951toLS3
clutch disc EmptySun Jan 26, 2020 4:51 pm by j7wolfe
clutch disc EmptySat Jan 25, 2020 6:42 pm by kevin924kevin
» Pedal Assembly - Which one?
clutch disc EmptyTue Jan 21, 2020 5:27 pm by Hotrodz of Dallas
clutch disc EmptySat Jan 18, 2020 7:15 am by Rothaus
clutch disc EmptyThu Jan 16, 2020 6:51 am by 87944turbo
» 82 924 with AUX Audi V8.
clutch disc EmptyThu Jan 16, 2020 2:11 am by Golten1986
clutch disc EmptyTue Jan 14, 2020 2:48 pm by Gumby
clutch disc EmptyTue Jan 14, 2020 6:43 am by 87944turbo
January 2020
6789101112
13141516171819
20212223242526
2728293031
clutch disc
clutch disc Empty clutch disc
Post  Porvette951 on Tue Feb 03, 2015 10:04 pm
Anybody out there using the centerforce 384070 or Ram 300 Series clutch discs with a Spec pressure plate and LS1 stock flywheel.  Just looking at other options besides spec.  Presume any combination so long as the clutch disc is less than the pressure plate diameter with some margin should work but interested in if anybody has any first hand experience.  Spline count of 23 and the 1" diameter input shaft are the same on the dodges as they are the 944's as far as I can tell.
Also, in general, is anyone using the unsprung race hubs.  With a 6 puck engagement may not be all that bad, just don't know how destructive it may be to the synchros over time.
Porvette951
Porvette951
clutch disc Empty Re: clutch disc
Post  Arthropraxis on Wed Feb 04, 2015 8:52 pm
I don't have one of those but there is no reason why it would not work. You will need to measure for a shim behind the slave cylinder. Be careful with your choice of discs. I have a Sachs disc IIRC with a 23 X 1in spline that was originally for a dodge. It fits but the splines are a little loose on the input shaft splines. You may want to look at whatever disc TPC the sponsor of this site sells, I would assume it fits well.
