Today at 6:48 am by Michael B.
» New 944 widebody & aero
» Oil Pan question
» 83' Porsche 944 LM7 Build
Broken clutch disc
Broken clutch disc
Post  948inVA on Mon Feb 22, 2016 4:14 pm
Pulled my clutch out due to issues I was having with shifting gears.  Initially I thought it would be a bad HTOB but I found these cracks and chipped section on the clutch disc.  The broken piece was loose inside of the pressure plate when I pulled it out, not sure if it just snapped off during removal or was stuck in there from before.  There are also a couple of hairline cracks around some of the other springs, similar to where the broken section failed.  Do you think this would prevent disengagement of the clutch?  The pressure plate and HTOB look fine so I'm still trying to figure out what was causing the problem.
948inVA
Re: Broken clutch disc
Post  sharkey on Mon Feb 22, 2016 11:45 pm
seen that many times in different cars. the piece that is broken off the hub ands up jamming between the clutch disc and the pressure plate (or if it were on the other side, the flywheel bolts and the disc) and because of it the clutch disc never stops turning. it acts like a bad htob, however the key difference would be that with this sort of failure the clutch pedal would feel fine. when the htob goes you end up with a spongy pedal, or lose the clutch pedal.
Post  948inVA on Tue Feb 23, 2016 11:02 am
Yep, describes the symptoms pretty much spot on. I'm thinking I'll just get the LS7 clutch kit to replace this. Anyone have a source/part # for the conversion disc that works with the LS7 setup?
948inVA
Post  Rich L. on Tue Feb 23, 2016 1:25 pm
Uhg, that sucks. What clutch disc is that that failed? OEM or aftermarket?
Post  948inVA on Tue Feb 23, 2016 2:46 pm
It's the TPC 11" conversion disc.
948inVA
