Is this normal?
+2
chris_f
6 posters
Is this normal?
The workshop carrying out my LS1 Conversion said they had to do this to the spare wheel well to make the transmission fit (due to the positioning of the engine). The car is a 91 944S2, Right hand Drive. Any input is appreciated.
chris_f- Posts : 12
Re: Is this normal?
I did not have to do that.
Re: Is this normal?
The back of my block is about a half an inch from the firewall and I did not have to modify the spare tire well.
Re: Is this normal?
I'd never seen this mentioned before so thought it seemed odd. Thanks for the responses so far.
Any ideas as to why this may have been necessary? a cause for concern?
chris_f- Posts : 12
Re: Is this normal?
Only things i can think of are that they possibly put the engine mounts (uprights) on backwards, or maybe they have the engine mount plates that bolt to the block on the wrong bolt holes.
This is all assuming everything is bolted up correctly, if there is a big gap between anything make sure the input shaft on the torque tube didnt get pushed back.
What bell housing are you using? C5 vette?
Techno Duck- Posts : 447
Re: Is this normal?
Techno Duck wrote:Only things i can think of are that they possibly put the engine mounts (uprights) on backwards, or maybe they have the engine mount plates that bolt to the block on the wrong bolt holes.
Thanks for the reply, the bell housing is C5 vette as supplied by TPC....
They did say everything was bolted up correctly, so perhaps it is the engine mounts.
These pictures should help re: engine mounts
chris_f- Posts : 12
Re: Is this normal?
No modifications to my spare tire well...
Re: Is this normal?
Hmm, it looks to me the uprights might be on the wrong side which would cause the engine to sit too far back like the problem you have. Maybe its just perspective but compare the angle of my uprights in these pictures
Re: Is this normal?
It looks like you may be right. Thanks for your help, I'll forward this on.
chris_f- Posts : 12
Engine position
Suggest you find a workshop that know what they are doing.
simon123- Posts : 125
Position of crossmember.
Another view
Another view
Re: Is this normal?
Thanks for the photos Simon. We've reached a resolution on this now and progress will continue on the car. Looking forward to getting the car back on the road.
chris_f- Posts : 12
