» Transaxle rebuild
» Hello, Gentlemen.
Yesterday at 7:43 pm by rawr
» alignment specs
Is this normal?
Is this normal?
Post  chris_f on Fri Aug 14, 2015 8:28 pm
The workshop carrying out my LS1 Conversion said they had to do this to the spare wheel well to make the transmission fit (due to the positioning of the engine). The car is a 91 944S2, Right hand Drive. Any input is appreciated.
chris_f
Re: Is this normal?
Post  Rich L. on Fri Aug 14, 2015 9:38 pm
I did not have to do that.
Re: Is this normal?
Post  Arthropraxis on Fri Aug 14, 2015 11:59 pm
The back of my block is about a half an inch from the firewall and I did not have to modify the spare tire well.
Re: Is this normal?
Post  chris_f on Sat Aug 15, 2015 3:15 am
I'd never seen this mentioned before so thought it seemed odd. Thanks for the responses so far.
Any ideas as to why this may have been necessary? a cause for concern?
chris_f
Re: Is this normal?
Post  Techno Duck on Sat Aug 15, 2015 6:28 am
Only things i can think of are that they possibly put the engine mounts (uprights) on backwards, or maybe they have the engine mount plates that bolt to the block on the wrong bolt holes.
This is all assuming everything is bolted up correctly, if there is a big gap between anything make sure the input shaft on the torque tube didnt get pushed back.
What bell housing are you using? C5 vette?
Re: Is this normal?
Post  chris_f on Sat Aug 15, 2015 6:40 am
Techno Duck wrote:Only things i can think of are that they possibly put the engine mounts (uprights) on backwards, or maybe they have the engine mount plates that bolt to the block on the wrong bolt holes.
Thanks for the reply, the bell housing is C5 vette as supplied by TPC....
They did say everything was bolted up correctly, so perhaps it is the engine mounts.
These pictures should help re: engine mounts
chris_f
Re: Is this normal?
Post  docwyte on Sat Aug 15, 2015 10:07 am
No modifications to my spare tire well...
Re: Is this normal?
Post  Techno Duck on Sat Aug 15, 2015 1:37 pm
Hmm, it looks to me the uprights might be on the wrong side which would cause the engine to sit too far back like the problem you have. Maybe its just perspective but compare the angle of my uprights in these pictures
Re: Is this normal?
Post  chris_f on Sat Aug 15, 2015 6:09 pm
It looks like you may be right. Thanks for your help, I'll forward this on.
chris_f
Engine position
Post  simon123 on Sun Aug 16, 2015 9:49 am
Suggest you find a workshop that know what they are doing.
simon123
Position of crossmember.
Post  simon123 on Sun Aug 16, 2015 9:56 am
simon123
Another view
Post  simon123 on Sun Aug 16, 2015 10:01 am
simon123
Another view
Post  simon123 on Sun Aug 16, 2015 1:19 pm
simon123
Re: Is this normal?
Post  chris_f on Wed Aug 19, 2015 10:01 pm
Thanks for the photos Simon. We've reached a resolution on this now and progress will continue on the car. Looking forward to getting the car back on the road.
chris_f
Re: Is this normal?
