fuel pump?
+2
murrayg
6 posters
fuel pump?
Hi all,
What are people using for a fuel pump? Is the turbo/S2 pump adequate?
Thanks!
Gord.
Thanks!
Gord.
murrayg- Posts : 105
Re: fuel pump?
Stock pump is fine unless you are adding a bunch of power adders. You should keep a return line.
Re: fuel pump?
My car still has the factory 944 pump. It's keeping up fine at 389 whp, a/f ratio was good all the way to redline on the dyno. This with the factory Vette fuel filter / regulator and dead-head fuel rail.
Re: fuel pump?
Walbro 392, pumps the same as the bosch 044 for a fraction of the cost ($100).
Re: fuel pump?
Thanks, I already have an S2 pump, so I'll use that with the Corvette filter.
Re: fuel pump?
Corvette filter with regulator has a return line at the filter that goes to the tank, which allows a single feed to the engine. This works well with the stock 944 pumps.
Re: fuel pump?
Factory pump on a return system. Plenty of fuel at 6K+ RPM for 380whp
money pit 951- Posts : 101
Re: fuel pump?
OK, thanks. Here's what I'm going to do:
-Use S2 pump in standard location.
- Add a Corvette regulating filter, to allow for return line operation. I assume this is to keep the pump happy?
- Locate the filter in the rear by the pump and use a single line forward.
Thanks for all the comments.
Gord.
Gord.
Fuel pump
Hello, so what is the max HP the stock pump can handle? My LS3 will have better than 525HP, will i need to upgrade the pump, i may have to upgrade my injectors.
kevin924kevin- Posts : 927
