» Transaxle rebuild
Today at 8:35 pm by matt889
Today at 8:27 pm by matt889
» Hello, Gentlemen.
Today at 7:43 pm by rawr
Today at 7:37 pm by Porsche951toLS3
Today at 7:17 pm by Porsche951toLS3
» alignment specs
Today at 12:53 am by sharkey
fuel pump?
fuel pump?
Post  murrayg on Sat Apr 05, 2014 5:20 am
Hi all,
What are people using for a fuel pump?  Is the turbo/S2 pump adequate?
Thanks!
Gord.
murrayg
Re: fuel pump?
Post  87-944S on Sat Apr 05, 2014 1:40 pm
Stock pump is fine unless you are adding a bunch of power adders. You should keep a return line.
Re: fuel pump?
Post  Rich L. on Sat Apr 05, 2014 4:58 pm
My car still has the factory 944 pump. It's keeping up fine at 389 whp, a/f ratio was good all the way to redline on the dyno. This with the factory Vette fuel filter / regulator and dead-head fuel rail.
Re: fuel pump?
Post  Lemming on Sat Apr 05, 2014 5:24 pm
Walbro 392, pumps the same as the bosch 044 for a fraction of the cost ($100).
Re: fuel pump?
Post  murrayg on Sat Apr 05, 2014 9:23 pm
Thanks, I already have an S2 pump, so I'll use that with the Corvette filter.
murrayg
Re: fuel pump?
Post  87-944S on Sat Apr 05, 2014 9:52 pm
Corvette filter with regulator has a return line at the filter that goes to the tank, which allows a single feed to the engine. This works well with the stock 944 pumps.
Re: fuel pump?
Post  money pit 951 on Tue Apr 08, 2014 8:48 am
Factory pump on a return system. Plenty of fuel at 6K+ RPM for 380whp
money pit 951
Re: fuel pump?
Post  murrayg on Tue Apr 08, 2014 11:15 am
OK, thanks. Here's what I'm going to do:
-Use S2 pump in standard location.
- Add a Corvette regulating filter, to allow for return line operation. I assume this is to keep the pump happy?
- Locate the filter in the rear by the pump and use a single line forward.
Thanks for all the comments.
Gord.
murrayg
Fuel pump
Post  kevin924kevin on Tue Apr 08, 2014 3:25 pm
Hello, so what is the max HP the stock pump can handle? My LS3 will have better than 525HP, will i need to upgrade the pump, i may have to upgrade my injectors.
Re: fuel pump?
