Renegade clutch fork?
Does anyody know what fork they used for their early style conersion? I snapped the clip that holds on to the piot.....yeah there is a letter or two on my keyoard that quit also haha, Thanks
tooms351- Posts : 50
Re: Renegade clutch fork?
I know that the slave cylinder was from a C4 Corvette, perhaps the fork is from that also?
Thanks,it looks close Ill have to get a measurement. I didn't know the slave was from a C4.
on the 928 5sp. kit uses an '84-'88 VETTE small (153 tooth flywheel) bellhousing, fork, and External slave.
also has a small pushrod between fork and piston (of slave).
simple,ugly and functional!
suboptimalfit- Posts : 61
Yes, it works good so I'm not ganna fix it! The fork has ben modified, from the part # its from an 86 chevy truck. Looks like it was cut and the push rod dimple moved, so I'll have to hit the parts counter and a torch.
