mcleod 12" x 1" x 23 spline clutch
I'm going to be getting a LT1 shortly; I just sold my old engine and transmission
I have a mcleod 12" x 1" x 23 spline clutch that I bought with the bellhousing adapter. I need to know if I can even use it? Is there a flywheel and pressure plate I can use with this clutch disk?
I just measured the disk itself and it measures 10 3/8"?
Spencer
Spencer
Re: mcleod 12" x 1" x 23 spline clutch
It's the manual SBC bellhousing; below are pictures of the exact adapter setup.
I'm sure someone else will chime in on this, but I think you will have to use the 10 1/2" clutch and flywheel set up with that bell housing. If it is a stock GM bell housing, I am almost positive that the 12" flywheel setup will not fit. The bell housing hits the fire wall in the car.
There should be a part number cast into the bellhousing somewhere. But it looks like a regular gen1 BH which will accept the 11+1" disc. (there seems to be a bug or something under my number "two" key on my laptop so I cant type twelve.
The renegadehybrids cast BH for the LT1 would NOT allow anything above 10.5" because its depth was a bit less than a stock GM housing. But, that BH looks like it will be fine. Was just working on a 67 and 65 corvette with a BH that is just like that one and they both get 11+1" clutch discs.
The part number on the bellhousing is 464697 (1978 GM A Body Bellhousing)... I can only use an 11" setup after doing some searching...
Should a 12" clutch actually measure 12" in dia? Like I said the one I have measures 10 3/8"?
Thanks guys
Thanks guys
Oh yeah youre right....just 11" for that BH. I also noticed that my old 10.5" clutch is not really 10.5" as well. So no I dont know why they listed it at 12" when its far from it. Weird. I also noticed that many people assume that the OD of the LS3/7 clutch disc was 12" but really its 11-7/16".
But saying its 12" but only 10-3/8" is really off and may be bad for a pressure plate/ flywheel thats a larger diameter??? I would call your local clutch guy to see whats up.....and then post it here!
944-LT1 wrote:Oh yeah youre right....just 11" for that BH. I also noticed that my old 10.5" clutch is not really 10.5" as well. So no I dont know why they listed it at 12" when its far from it. Weird. I also noticed that many people assume that the OD of the LS3/7 clutch disc was 12" but really its 11-7/16".
Could you do me a favour and measure your old clutch? (if you still have it)
» New, unused FRH conversion clutch disc, 12"
» 944 transmission input spline
» upgrading to 33 spline 930 chromoly stub shafts
