» ecotec swap
Yesterday at 7:02 pm by sharkey
» What is VSS?
Yesterday at 10:53 am by C4924S
» The famous Hydroboost issues....
Yesterday at 10:43 am by Hotrodz of Dallas
» RHD Conversion Issues...
Sun Apr 22, 2018 4:24 pm by UK952
» Considering doing LS1 Swap
Sat Apr 21, 2018 10:29 pm by hooplajr5
» WTB: 944 Turbo Roller
Sat Apr 21, 2018 8:31 am by Maxx
» Blue Alternator Wire
Fri Apr 20, 2018 11:22 pm by Porsche951toLS3
Thu Apr 19, 2018 4:01 pm by Murrdog9000
» Team Moroney's LS1 944 Swap, In memory of Kyle Moroney.
Thu Apr 19, 2018 6:16 am by bikerdude
Thu Apr 19, 2018 2:33 am by Flashy2003
April 2018
30
944 transmission input spline
Post  grtoz on Sun Aug 04, 2013 12:51 pm
I would like to know if the input spline on the 944 transmission is compatible with a clutch disc if it is i want to try to use the transmission in a 914 because the gearing is better and stronger.I know i will have to make a bell housing adapter and change the shift linkage but the main problem is can i get a clutch disc to fit the spline. Thank You
grtoz
Re: 944 transmission input spline
Post  Admin on Sun Aug 04, 2013 5:05 pm
Posting it in the proper section will get you better answers.....
What is the spline count of the 914 clutch disc?
Post  944-LT1 on Sun Aug 04, 2013 6:38 pm
944 = 23t x 1"
914 = 24t x 0.81"
Post  marc a on Mon Aug 05, 2013 1:07 pm
Actually the problem is that the 944 transmission does not have a taper for a pilot bearing because the main shaft is coupled to the drive shaft of the torque tube.  Not sure if the splines on the main shaft are the same as the splines at the clutch end of the torque tube.
Clutch.net will make any clutch if you give them the dimensions of the hub, overall diameter, and inner diameter of the pressure plate.
marc a
