Electric brakes vs. Hydroboost
I'm not familiar with either system, but which is the better solution? Where is the best place to research both systems?
billymild- Posts : 24
Re: Electric brakes vs. Hydroboost
Both work equally well, do a search or just browse the brake section. There is more information on hydro-boost than electric, mainly due to there are many OEMs that have hydro-boost systems, so they tend to be less expensive.
I would skip the electric. I have one on my car and its just ridiculous. A lot of sending parts back to ABS Power Brakes for rebuild... Both my motor and my master now... UGH...
zeusrotty- Posts : 444
I'll sell my ABS Power Brake setup...has 10,000 miles.
rdanford- Posts : 96
Which setup do you have?
zeusrotty wrote:Which setup do you have?
10-59...10,000 miles on first pump and now 700 on the 2nd dead pump.
rdanford wrote:zeusrotty wrote:Which setup do you have?
Does the pump run and just not pump? Or is it just dead?
Just runs...same thing as last time and it had to be rebuilt for $150
Do you know what they are doing to rebuild it? I took one apart and there isn't much to it... I'm wondering if there is another place that can rebuild them.... I'm currently having the same issue. So I'm either going to scrap it and do a pedal box, or I'm going to try to fix this setup one more time.
This motor has to be out of another vehicle. I'd like to find out which so I can just try to have it bought from rock auto. I'd rather not give them any business at all.
I have no idea what they are doing to it. If it wasn't for the initial cost I'd scrap it and go hydro, but dang, I have $1000+ into it.
okay, I have found some new information. These pumps are actually hydraulic abs pumps. Looking like they were made for jags and or range rovers... Now we just need to find a better company to rebuild them...
Looks an awful lot like the Jag X300 pump:
http://www.eurojag.com/jaguar-abs-pumps-modules-c-327/jaguar-x300-abs-pump-ecu-without-traction-control-mna5920ab-p-907.html?zenid=q4rh1h48jkd0q9js6v31m13h55
Yeah... I'm hearing they are made for a Lexus though... But now that I'm looking at it that could be for the mustang system.
This explains a lot. I never heard of many electric, but only two to four. No complaints until above.
https://youtu.be/MpAhXrLpvZo
See all of the shows... Lots of info.
gamman- Posts : 112
I can definetly say that there product is sub par... ABS Electric that is...
» Electric brake booster setup for the 944 PRICE DROP!
» Electric brakes
» Question on the ABS Power Brakes (electric setup)
» Electric brakes
