Building a LS1 968 track day project car
+13
charlie1175
stu wright
ROGUE S2
skywalker01
968LS3RS
Diyman25
17 posters
Page 1 of 3
Page 1 of 3 • 1, 2, 3
Hi every one , I am building a ls1 968 6mt track day car , and was thinking to use 951 Transmission to
suitable the tq, beside the 951 transaxle and torque tube what else I need to complete
Ps is hard for me to get part in my country , so I want ship all the parts at once , I already get the car running with ls1
Thanks for ur time
J
Thanks for ur time
J
Diyman25- Posts : 79
Re: Building a LS1 968 track day project car
Diyman25 wrote:Hi everyone. I am building a ls1 968 6 speed MT track day car and was thinking of using the 951 transmission suitable for the torque. Beside the 951 transaxle and torque tube, what else would I need to complete this?
It is hard for me to get parts in my country so I would want to ship all the parts at once. I already got the car running with ls1.
Thanks for your time
J
I believe you will also need the CV joints as the 968 CV's were different lengths. The mount for the 968 and 951 transmission (I believe) may be different as well. Besides that, I cant think of anything else you would need.
944-LT1 wrote:Diyman25 wrote:Hi everyone. I am building a ls1 968 6 speed MT track day car and was thinking of using the 951 transmission suitable for the torque. Beside the 951 transaxle and torque tube, what else would I need to complete this?
J
Fox the CV I will order GkN motorsport axle , and as for mount I will need to find out
Hope all the shift linkage will be similar
But I think I will wait until I get a right LSD install and swap all at once
Right now I will just try to live with close ratio 6mt
Diyman25 wrote:Right now I will just try to live with close ratio 6mt
Yeah, Im not sure about the shifter linkage either. I thought there was one or two guys on this forum with 968s. Hopefully they will chime in soon?
You will need the Torque tube, Transmission, shifter linkage(the tube part), and the mount. You will need to make spacers for the transmission mount as well. It needs to be spaced down about an inch.
Thanks every one for help
I already bought two 951 transaxle one with cooler one without , In my country there are less then 20 951 exist so I better stack my own spare part
one 944 torque tube , shift linkage and mount , only thing I need is Motorsport axle and LSD
Last edited by Diyman25 on Sun May 06, 2012 10:09 am; edited 1 time in total (Reason for editing : Add word)
Gear count
You talk about a six speed track car, the 951 transmission is 5 speed unless my 951 transmission has a hidden gear somewhere.
fliermike45 wrote:You talk about a six speed track car, the 951 transmission is 5 speed unless my 951 transmission has a hidden gear somewhere.Hi everyone. I am building a ls1 968 6 speed MT track day car
I wish I can find a missing gear too
finally recive my long wait porsche 968 from state
i love the idea of german chassic and LS1 power car !!!
however i have issue of car runing hot on water. after the warm out the temp show on stock on gauge is pretty high above 1/3 upper part if i did some wot test the temp will rise to redzone....
which bother me a bit.. any idea what kind of radiator i can be use ?
since i am all the here at asia i cant just order part fom summit or jeg
so i would like know the size of radiator, that i can have shop build one here
thanks for your time
J
Sounds like you have air in the system. Remove the small hose from the front on drivers side head, remove the radiator cap and put the small hose into reservoir and run engine. You might have to do this for several minutes and rev the engine to move any tapped air. Engine should run between first and second lines on the gauge when bled properly.
968LS3RS- Posts : 10
968LS3RS wrote:Sounds like you have air in the system. Remove the small hose from the front on drivers side head, remove the radiator cap and put the small hose into reservoir and run engine. You might have to do this for several minutes and rev the engine to move any tapped air. Engine should run between first and second lines on the gauge when bled properly.
This is what I plan to do next
The shop who did the install
Have a vale on one of heater line , I think this is for bleeding air
But in the hot weatther where I live (100+f) I think bigger radiator is need it
J
Bleeding system three time in 2 days. the water temp seen to be stable a bit
will drive it tonight to find out
next week will go to friend place to make trul dual with crossover pipe
the current set up. is cat back with 968 factory system... i can only say it is really quite !!!
and people will think you have a lot of missfire in your engine instead having V8........
before that will do a dyno pull to see how many horse i get under bonnet
i have LS1 engine with TR 224 cam and the support mod but with untune ecu. i am hopping aleast get 340whp from bosch roller dyno !!
J
J
this week will target on new exhaust system
my high flow cat. i try to find out the smallest i can fit under so i dont have too much restriction
most of piping. the muffler is going to made by my application
compare to my stock 968 catback now
new system should be very promising !!! either in sound or performance
Looks like a very nice swap! Let us know how the exhaust works out. It should make a big difference!
some update of the exhaust
just mocking out the posion.... so far so good
2.5 inch SS pipe all the way with Vband
Final part of welding
how to muffler look from the side
Really nice job, is that the x-pipe under the tunnel brace or just how the two exhausts were routed?
Techno Duck- Posts : 447
Techno Duck wrote:Really nice job, is that the x-pipe under the tunnel brace or just how the two exhausts were routed?
Is a X pipe design
Wow, that is sweet! I do like the pipes on top of each other for the outlets, awesome work, now post some audio man!
87-944S wrote:Wow, that is sweet! I do like the pipes on top of each other for the outlets, awesome work, now post some audio man!
Thanks for kind word
i get the inspire from harley davidson aftermarket pipe
the car is really quite on idile i will try to film it when i dyno test it next week
J
Update
every since i get LS1 in 968. it have issue of bad oil leaking with RH pan.... it even eat out my caster
block.............
finally have enought of it .. pull it out and .... was suprise how wrap it is...................
find some create way of filling out of wrap area
machine some derlin block for my caster block nice and it work most of time
[img][/img][img][/img]
block.............
close shop my caster block, with heat shield
close shop for my radiator.... custom made super wide two row... hope this will cure my cooling issue
i guess 90% of people on this forum own 944
so 968 LSX is rare kind
some update of the project... will be out of town for business for 3 week....
what is best thing to do ? drop your car to body shop to have fresh coat of paint and install
wide body
last night test fit some old school 930 turbo wheels !! the result is just what i expect it !!
cant wait to see it when i am back from trip
wide body
going replace my current 918 to this 925 double spring
Page 1 of 3
