Flywheel offset 85.5 944
Does anyone know the distance from the flywheel surface to the stock bellhousing mounting surface?
I am dreaming up a non-typical swap, and THINK I can get away with an adaptor plate between with the bellhousing and my block. I believe the flywheel I am using is much thicker than the ones I am seeing stock for 944s.
backpack09- Posts : 12
