Koni yellow rear adjustable shocks on an '83 948 with 28mm torsion bars
+5
RobotMachines
9 posters
Page 2 of 2
Page 2 of 2 • 1, 2
Re: Koni yellow rear adjustable shocks on an '83 948 with 28mm torsion bars
944-LT1 wrote:Shock absorber to body bolt/nut 45 ft-lbs + 1 yellow zip tie
Shock absorber to steel trailing arm nut/bolt 45 ft-lbs + 4 yellow zip ties
Shock absorber to aluminum trailing arm bolt/nut 90 ft-lbs + 2 yellow zip ties
Just finished putting in the other shock and used your torque specs. All I have to say is...
I only had one yellow zip left that could find. It's on there (time to buy more).
RobotMachines- Posts : 165
Iz cAN SEE IT!!!
Crazy thing is, it will still be there when these shocks are shot.
87-944S wrote:944-LT1, that is so funny, I think I peed a little!
944-LT1 wrote: Iz cAN SEE IT!!!
Yellow zips are are like gravity. <-- yah
Off to test out the machine.
.. then to bed
Question is: how do the zip ties on the front of the car look, are they still there???
948 wrote:944-LT1 wrote: Iz cAN SEE IT!!!
Oh, they're still there... and they look great!
Drove the big go-kart to work today and all is well now with the suspension.
Do yo guys know of anyone that has all of the old pictures/albums from Doug's old 560sec hybrid site?
I had a lot of good pictures in there
Nope. The whole site was gone within a year I think as soon as RH got ahold of it. Everything was lost. But, its all safe here to start again! Setup a gallery!
Sucks. Well, you're right, time to take some more pictures.944-LT1 wrote:Nope. The whole site was gone within a year I think as soon as RH got ahold of it. Everything was lost. But, its all safe here to start again! Setup a gallery!
RobotMachines wrote:Sucks. Well, you're right, time to take some more pictures.
Bring on the poop!
944-LT1 wrote:RobotMachines wrote:Sucks. Well, you're right, time to take some more pictures.
Bring on the poop!
i called koni the other day about rebuilding a set of struts and shocks. the said for struts its 139.00 plus parts. shocks like 120.00 plus parts and they will valve them however u want.
shokwave30- Posts : 68
Page 2 of 2 • 1, 2
» Rear Spring Length - Coil Over Conversion w/No Torsion Bar
» 250 pound front springs and 28 mm torsion bars?
» WTB 968 m030 rear shocks with helper springs
Page 2 of 2
