WTB: TT bearing carrier
Hi all,
I'm in need of a good TT bearing carrier, the part that goes on the the outside of the bearing between the TT and the bearing.
If you have a good sleeve, that goes between the shaft and the bearing, I'll take that too.
Thanks!
Andy
Thanks!
Andy
acorad- Posts : 697
Re: WTB: TT bearing carrier
Thanks Mike, great idea.
acorad- Posts : 697
If you can't find one make one, or all 4 like I did, from Delrin.
I think Clarks only has the plans for the inner sleeve between the drive shaft and the bearing, are there plans for the outer carriers? That donut between the TT tube and the outside of the bearing?
acorad- Posts : 697
I thibk Xschop was making bearinbg carriers in his TT thread.
Sorry, I must have skimmed your post and only read the last part....acorad wrote:I think Clarks only has the plans for the inner sleeve between the drive shaft and the bearing, are there plans for the outer carriers? That donut between the TT tube and the outside of the bearing?
Ask Rob about replacement bearing holders.....
» So....I think i need a throwout bearing
» I need some help with the pilot bearing
