Power Rack Fitment
Power Rack Fitment
Howdy All. I'm having trouble fitting my steering rack. The hard hydraulic lines that are part of the rack are interfering with the oil pan. The feed and return lines I can setup however I need. But these lines from one point on the rack to another I was hoping to leave alone. Do you guys that use a power rack cut and splice them to make clearance?
In this picture my red line shows roughly where the oil pan is:
Thanks for any thoughts.
Clearance
What type of oil pan are you using?
I just pointed my camera in the vicinity of my oil pan/rack, check this:
Last edited by fliermike45 on Sat Jan 28, 2012 5:56 pm; edited 1 time in total (Reason for editing : Added pic)
Clearance
Cut a piece of tube in half, cut and weld it into the oil pan to give you a clearance channel in the area of the rack plumbing.
Re: Power Rack Fitment
Don't cut anything, you can bend those lines down and out of the way. I did this on my Moroso pan. Also I trim some of the steering rack alloy boss from that side of the X-member as well. I'm doing two X-members that way today.
Loosen that banjo bolt next to your blue glove and that makes the bending easy, then retighten.
Just tap them down with a rubber hammer. I've done it on every car I've built. They will move enough to clear the pan.
