custom torque tubes or ideas to mount a 930 transaxle
Page 1 of 1 • Share •
a year ago or so, I purchased a 930 long bell housing with dreams of using in a 944. I know those things will take a ton of abuse and the gear ratios would be ideal for a lightened car and v8.
Anyone have fab skills or know how to accomplish this. I know that the diff will need to be flipped and I am sure that it will be a nightmare trying to make a shift linkage too.
any ideas?
any ideas?
89 944- Posts : 8
Re: custom torque tubes or ideas to mount a 930 transaxle
I dont have anything for that transmission but a boxster transmission has been done! From what I remember, most of the bellhousing bolts lined up with the 944 torque tube so no real need for an adapter.
trans
hehe. Looks like I will need to get a mig welder from Harbor Freight.
89 944- Posts : 8
shift linkage
Threre are a few co. that make real nice cable units for the G50/50, so they may have something already designed.
kevin924kevin- Posts : 806
cool idea!
there are so many more high HP options for 911 based transmission!
In hindsight I should never sold my 924 turbo transaxle and torque tube! The "snailshell" trans is very similar to the 901 trans.
Pete, (CarreraGTS) is more on an expert on this topic though...
The snail shell is similar to the 915 not the 901. Many parts are 915 parts and the OEM LSD is from the late 930. (930.332.053.03)
The 930 transaxle has a very different bellhousing than the 944. It is basically round like the air cooled VW's. It's very bullet proof and has a 9" ring gear.
The Boxster is more like the 944 but from what I know (second hand) it isn't as strong as the 951.
v8carreragts- Posts : 327
What's the BH pattern on the 930 trans?
xschop- Posts : 2710
Life
Marc/xschop
If you could figure this out for the v8/high $ turbo/racing community, you would/should/could have a lot of buyers. I am about to pass on a super car because the gearing in the car is atrocious. So, you need to fix 170k mile trans with the same gears? Yuk. Some guys have 4-6k in theirs, rebuild2k, LSD2k, cryo/hardened 1k, no custom gear sets. Those are upto 2-4k.
It is the only reason why I believe that some stop racing them. Just not enough reasonable price options.
That guy in Vegas has spent as much as the car I was looking to buy.
gamman- Posts : 110
The 901/915/930/G50 all use the same bellhousing pattern. Somewhere I have the dimensions but it will take a little time to find them. It is also the same as the air cooled VW The early transaxles (Porsche) used a 215mm clutch, then they went to 225mm and finely to 240mm.
» What is VSS?
» RHD Conversion Issues...
» Considering doing LS1 Swap
» WTB: 944 Turbo Roller
» Blue Alternator Wire
