F-Body Windage Tray vs. Y-Body Windage Tray
Is there any advantage to using the Y-Body windage tray versus the F-Body? The Y-Body tray is longer, it covers the whole crank where as the F-Body covers 3/4 of the crank. I dont know about pick up tube or dip stick interferences.
What do you think?
What do you think?
Re: F-Body Windage Tray vs. Y-Body Windage Tray
I’m using the stock L92 (Gen IV 6.2L) windage tray which is also full length and looks just like the vette’s (y-body)…with no interference from the pick-up tube, etc
Someone please chime in if this is a mistake while the mill is still on a stand.
944convert- Posts : 253
Mine has the vette tray. Its a vette engine and with the customized Moroso oil pan, I had to fit the aftermarket Milodon 18290 pick up tube....no problem fitment wise at all.
I am using the full length tray found in the LS6/CTS-V. Fits the TPC pan and pickup perfectly
eclou- Posts : 102
Part # 12558189 is the full length model. Bought one brand new for $16 ($28 shipped).
