Need some dimensions on rack and pinion mounts
I got the front half of the aluminum mount that retains the rubber mount with the rack. As I am not using the aluminum cradle from the 944, which has the other half of the mount, would someone be so kind to supply some dimensions?
I have shown the dimensions I need sketched in this photo, but I need them from the aluminum parts, not the bushings.
I would need these from the outer clamp retained to the inner clamp on the crossmember, not from the bushing itself, for it would be somewhat larger than the aluminum.
A= back to front of radius
B= height
R= radius in the corner
Digital caliper readings would be a plus.
Thanks again for everyone's help.
B= height
grobb284- Posts : 36
Re: Need some dimensions on rack and pinion mounts
Took these off Allen's modded X-member....
What program doe you use?
Eric,
What program do you use to do the beautiful annotations on your pics?
And are you saying these annotations are not beautiful?
However they did serve their purpose.
Sorry
Sorry Eric, I mixed you and Rob up, sorry Rob I mixed you and Eric up.
» Question on rack and pinion with LS1, hydroboost.
» Other Transaxles
» 85.5 CV joint bolt dimensions
» Other Transaxles
