Ring and Pinion swap?
Hello,
Is it possible to swap a turbo transmission ring and pinion with the 8:27 (3.375) final drive into a 944S AGR transmission?
According to http://www.clarks-garage.com/shop-manual/trans-04.htm the turbo trans are 016 type, and the AGR is 083. Does this make a difference?
Thanks!
Thanks!
GarethW- Posts : 26
Re: Ring and Pinion swap?
You can swap the 951 R&P in the 944S transmission. The 1st-5th gears are the same between the two transaxles as well as the cases but you are better off finding a 951 trans. I usually carry a few in stock.
» Wanted: Ring and pinion gear set.
» Question on rack and pinion with LS1, hydroboost.
» Please remind me which port is pressure side on 944 rack and pinion
