Flywheel offset 85.5 944
Does anyone know the distance from the flywheel surface to the stock bellhousing mounting surface?
I am dreaming up a non-typical swap, and THINK I can get away with an adaptor plate between with the bellhousing and my block. I believe the flywheel I am using is much thicker than the ones I am seeing stock for 944s.
backpack09- Posts : 12
Today at 4:30 pm by ThomasJoseph315
Today at 8:08 am by gwistrup
Yesterday at 11:12 am by Nath1142
Mon Apr 22, 2024 8:22 pm by lowform
Mon Apr 22, 2024 8:12 pm by lowform
