LS1 Power Steering Pump Delete Questions? belts, pullies, w/o GM pump?
Hi all,
Getting through my project and I'm at a point where I have an engineering question!
I did a manual steering rack on my conversion : 87 944/LS1 and was curious if anyone knew my options for a PS delete pulley that runs with the stock F body drive belt? Just need to turn WP, A/C and alt.
Came across this and wondered if anyone had used or had a more cost effective alternative?
LS1 Camaro Firebird PS Power Steering Delete:
Many thanks in advance!
Last edited by 944_345.7 on Thu Apr 28, 2011 2:50 pm; edited 1 time in total (Reason for editing : mistake)
944_345.7- Posts : 4
Re: LS1 Power Steering Pump Delete Questions? belts, pullies, w/o GM pump?
Only takes an idler pulley, do a search on LS1tech.com the is a hundred solutions. With pictures
This is what you are looking for:
