87 S with 2004 GTO LS1
+15
pormgb
Powerman951
zeusrotty
modenas
skywalker01
eclou
Schuepbach
19 posters
Page 4 of 4
Page 4 of 4 • 1, 2, 3, 4
Re: 87 S with 2004 GTO LS1
They were made by:
Nice guys, very satisfied with the final product. Yes, for the rears 4 inches out, fronts, 2 inches out. The rears are 12 inches, fronts are 9.5. Those were the optimal sizes for the Toyo R888s that I chose. They can make them in any size up to 13 inches wide. These are 18 inches in diameter.
Valve Cover
I've been working on the BMW hydroboost install lately. During all the incarnation of brakes I have went through, I ended up scratching my painted valve covers. A repaint was in order, and I hated the three extra bosses left showing when I moved to truck coils. So I cut them off and ground down the stubs with a flapper disk. There were small indents left from the mounting bolt holes, so I used a little JB Weld as a filler.
It goes back in today, along with the coil packs.
Gorgeous Mike! Great job on the valve covers! Hey man, I'd love to chat about your hydroboost install sometime, as i'm considering doing it myself...let me know when you'd like to chat!
Ethan
Ethan
v8944- Posts : 211
BMW Hydroboost
Here's my BMW hydroboost so far, I'm waiting on some fittings to hook up the high pressure, and some hose for the low pressure.
Hydroboost exploded, the aluminum part is a replacement for the plastic cup, which often cracks. I rebuilt it with all new seals, o-rings, etc.
BMW M/C painted with epoxy paint, booster was painted as well.
Regulator and nitrogen "bomb" mount details behind drivers headlight
Truck coils back in, lines hooked up, and stock Porsche reservoir in place.
Last edited by 87-944S on Sat Sep 29, 2012 9:30 pm; edited 2 times in total (Reason for editing : added more pictures)
Question, did you turn the unit a bit to the right?
kevin924kevin- Posts : 927
Long time to respond, but no, I did not offset the M/C. Using the truck coils made everything clear easily.
Page 4 of 4
