» Fuel tank over pressurizing
» LS Conversion Kit Plus
» tips on removing headers?
» Oil Pressure
» Mass oil leak!?
» SBC Pilot Bearing
» Lighten clutch pedal feel?
February 2019
87 S with 2004 GTO LS1
Page 2 of 4 Previous  1, 2, 3, 4  Next
Re: 87 S with 2004 GTO LS1
Post  944-LT1 on Tue Dec 27, 2011 9:43 pm
Wow!! Those look great!
Post  skywalker01 on Wed Dec 28, 2011 5:29 am
The quality of these panels definitely show. Pictures do not do them justice! Fortunately Mike likes the cold, so you'll see much progress on this before the spring!
skywalker01
skywalker01
Post  xschop on Wed Dec 28, 2011 6:12 am
Very Happy
Mike, those will do some Mickey Thomsons proud. Custom width wheels or just spaced out?
here is the interim solution until I learn enough about tuning this engine
Post  Powerman951 on Wed Dec 28, 2011 8:07 am
Mike,
Any update on your intake solution?
Dan
87-944S wrote:Ok, well, here is the interim solution until I learn enough about tuning this engine. This is a few 4 inch to 3.5 inch silicone adapters, and the original 3.5 inch MAF fits nicely to the SLP Blackwing air cleaner. The engine runs well with this setup, but there is always room for improvement!
If I keep this, the elbow has to be painted red!
Powerman951
Powerman951
Post  87-944S on Wed Dec 28, 2011 8:31 am
Currently just spaced, 8.5 x 18 inch front rims, and 8 x 10 out back. I have one inch spacers for the fronts and two inchers for the rears. Once the body work and paint are done I may think about some custom wheels like Skywalker. After the wallet recovers from Xmas! Shocked
No progress on the intake, will get back to that when the weather is warmer and the body panels are done. I have a few minor changes to the exhaust that I want to get sorted before playing with the intake again.
I am enjoying the change from working on the brakes to the body panels. Seeing a big visual change is a great motivator!
Post  Admin on Sat Dec 31, 2011 10:53 am
zeusrotty,
Those are my wide body parts, this is the first set that I have let leave the shop. This is one of two sets in existence . You won't see these any where but here, and here! Cool
Post  Admin on Sun Jan 08, 2012 5:46 pm
8 Day's of nothing? What the hey? Sleep
Post  skywalker01 on Mon Jan 09, 2012 6:35 am
Mike is slightly distracted, with that one task we all dread: Home maintenance! He should be back with updates shortly!
skywalker01
skywalker01
Back at it!
Post  87-944S on Sat Jan 28, 2012 7:14 pm
I have been away due to work travel and dreaded issues with the house as Skywalker said. Here's some pics of the front at the end of the year. Pics of the rear from today, and a few from the front today with wider spacers. Still too cold for me to bond these on, and I will post the backside of the rear flares to show trim detail next time I take them off. Not a whole lot of trimming to do, thanks Admin!
1 inch spacer detail
Need to extend stock front air dam, I may go for an aftermarket unit
Ok, here's some pics of the rear flare, comparing stock, rear flare with no spacer, 2 inch spacer, I will add more detail of the install, including what I cut off the fenders. This is not a difficult install, I will have shots of a 4 inch spacer in a few weeks when they come in. Ultimately, I will have custom rims made, so I will have no spacers (spacers are NOT a problem if properly engineered!) My rear tires are currently 265s on 18 x 10 inch rims. I am planning on 335 Toyo R888s 18 inch x 12 rims for the rears, 265 or 275 on 9 inch for the front. Tires and rims in the pics are new, and will go up for sale soon. Smile
Those 265s used to look pretty wide!
Post  Arthropraxis on Sat Jan 28, 2012 7:18 pm
Those fender flares really look good. It will be awesome with the fat tires back there. What exhaust tip is that?
Post  87-944S on Sat Jan 28, 2012 7:22 pm
The exhaust tip is a magnaflow 5 inch oval Stainless Steel with baffles, pricey at 125 or so, but I like it!
Post  Arthropraxis on Sat Jan 28, 2012 7:41 pm
That is the one I have been looking at but haven't been able to find a picture of it installed. I will order it now.
Fronts with 2 inch spacer
Post  87-944S on Sun Jan 29, 2012 9:58 am
Here is one more pic of the rear flare, and few pics of the front tires spaced out two inches. They now fill the fenders perfectly.
More to come as I get a chance to work on it some more. I really like how this is turning out! Very Happy
Last edited by 87-944S on Sun Jan 29, 2012 10:03 am; edited 1 time in total (Reason for editing : Added a pic)
Post  pormgb on Sun Jan 29, 2012 1:02 pm
Is the stock N/A front spoiler wide enough to meet the fenders?
pormgb
pormgb
Post  87-944S on Sun Jan 29, 2012 3:34 pm
Wide enough yes, but a small extention is needed, take a look at one of the front fender pics and you can see what I mean.
Post  pormgb on Sun Jan 29, 2012 3:54 pm
87-944S wrote:Wide enough yes, but a small extention is needed, take a look at one of the front fender pics and you can see what I mean.
Ok, Thanks!!
pormgb
pormgb
Not your Daddy's spacers!
Post  87-944S on Wed Feb 15, 2012 7:06 pm
These arrived today, 4 inch spacers for the rear.
These will allow me to get a good idea of how everything will look and fit. These are hub and wheel centric, made in the USA. Very Happy
I got them from [You must be registered and logged in to see this link.] they will make any size up to 5 inches wide for Porsche.
Last edited by 87-944S on Wed Feb 15, 2012 7:13 pm; edited 1 time in total (Reason for editing : Added source for spacers)
Custom Rims
Post  87-944S on Wed Feb 22, 2012 8:15 pm
Ok, so, here is what I am planning on for custom rims that will fill out those sweet flares!
Toyo R888s in 335 30 18 on 12 inch rims for the rear, 265 35 18 on 9 inch rims for the front. They can also do custom engraving for the center caps. Skywalker suggested the Hybrids crest, going to see if they can do that. Otherwise a 948 script will work! I haven't decided on a spoke color, open to suggestions. Very Happy
Post  944-LT1 on Wed Feb 22, 2012 9:45 pm
Oh mama...those are super awesome! Center caps with "944-LT1" would look good on your car. Polished spokes an option?
Post  87-944S on Thu Feb 23, 2012 6:41 pm
Yep, polished is the default, brushed satin, colors, chrome, etc. Leaning towards brushed satin for the spoke surfaces.
Rear tires!
Post  87-944S on Sun Feb 26, 2012 8:09 pm
My Toyo R888s in 335X30X18 for the rear came in!
Here they are compared to the 235s on my SUV. Shocked
Can't wait to see how they look with the flares!
Post  Arthropraxis on Sun Feb 26, 2012 8:32 pm
Good God those are huge. I was happy with my 255's.
Post  xschop on Sun Feb 26, 2012 8:37 pm
Dayum Shocked
Those should have a USDA stamp on 'em somewhere Very Happy
Post  Techno Duck on Sun Feb 26, 2012 9:24 pm
Nice! I love ├╝ber wide tires, those put my 285/18's to shame!
Post  87-944S on Sun Feb 26, 2012 9:28 pm
I think I saw USDA Prime stamped on the inner lip! Laughing The fronts will be 255s,I know these are way overkill, but what the heck. Rob, I think I may need a set of those cool chromoly axles! Cool
