Tue Jul 09, 2013 4:56 am by Admin
90 Cab swap
+5
modenas
9 posters
Page 1 of 2
Page 1 of 2 • 1, 2
Re: 90 Cab swap
Thanks. A green wire you say. I'll have to look.
Dawgz83948- Posts : 603
Re: 90 Cab swap
Yep! But remember, if it wasnt used on your car, there may not be a wire there. You may need to add one.
I hope this helps,
Mark
I hope this helps,
Mark
Marky522- Posts : 175
Re: 90 Cab swap
Marky522 wrote:Yep! But remember, if it wasnt used on your car, there may not be a wire there. You may need to add one.
I hope this helps,
Mark
My car had a functioning Check Engine light on the dash. IDK why the diagrams don't list it, but it used to light up and go away when the car was being started.
Re: 90 Cab swap
She started. Gotta finish the gauge wiring and clean up the under dash stuff.
Re: 90 Cab swap
I just want to verify, grn/blk is the tach wire right? That is number 2 under the dash, but on my car there are 2 wires that are combined on #2, is that normal?
Re: 90 Cab swap
Yeah, connector T1 [passengers compartment footwell] at pin 2 is the GN/BK wire. This braches off at pin 2 to the T26 diagnosis plug in the engine compartment.
You can also grab this wire at pin 3 of Plug B behind the instrument cluster.
I made you a simplified shematic of the wire path.
Re: 90 Cab swap
944-LT1 wrote:Yeah, connector T1 [passengers compartment footwell] at pin 2 is the GN/BK wire. This braches off at pin 2 to the T26 diagnosis plug in the engine compartment.
Thanks. I just wanted to double check before I short something out.
Re: 90 Cab swap
No problem. To be honest, the schematic wasnt really for you... I know you know where its at but for others who search.... there it be.
Re: 90 Cab swap
She lives.
Before:
After:
Need to weld the exhaust back on.
Before:
After:
Re: 90 Cab swap
Congrats!!!
Re: 90 Cab swap
Looks great, congrats. Are you running OBDI or OBDII?
laptop_geek- Posts : 230
Re: 90 Cab swap
OBD1. Easier to smog in California.
1st Fire Open Header
Full Exhaust Top down
Rear Suspension
Are the rear coil overs in addition to the torsion bars?
Re: 90 Cab swap
fliermike45 wrote:Are the rear coil overs in addition to the torsion bars?
Yes. They are 150# springs and really cut down on the squat under power.
Re: 90 Cab swap
Sorted my over heating issue. In the end though it was just a stuck thermostat.
Intake.
Re: 90 Cab swap
WOOOHOOOOOOO!!!! She's legal.
Re: 90 Cab swap
Great news!Dawgz83948 wrote:WOOOHOOOOOOO!!!! She's legal.
acorad- Posts : 697
Re: 90 Cab swap
Dawg, I know it's too late now, but check this out:
These counties require smog check only in certain zip codes.
El Dorado
Placer
Riverside
San Bernardino
San Diego
Sonoma
These counties do not require smog check.
Alpine
Amador
Calaveras
Del Norte
Humboldt
Imperial
Inyo
Lake
Lassen
Mariposa
Mendocino
Modoc
Mono
Plumas
Sierra
Siskiyou
Trinity
Tuolumne
acorad- Posts : 697
Re: 90 Cab swap
Figures, I have friends that live in Tuolumne. Ohh well, it's done now.
acorad wrote:Dawg, I know it's too late now, but check this out:These counties require smog check only in certain zip codes.
El Dorado
Placer
Riverside
San Bernardino
San Diego
Sonoma
Alpine
Amador
Calaveras
Del Norte
Humboldt
Imperial
Inyo
Lake
Lassen
Mariposa
Mendocino
Modoc
Mono
Plumas
Sierra
Siskiyou
Trinity
Tuolumne
Re: 90 Cab swap
My latest addition. Worth every penny.
Re: 90 Cab swap
As you all know the 944 and 968 cabriolet have an electric pop mechanism for the trunk. Porsche got their head out of their butt with the 968 and made an emergency release for if/when the electric system fails. Unfortunately for us 944's do not have this, however this is what I did. Maybe this will help some of you do make an emergency release.
Remove the latch.
Remove the round pull out of it's holder. As you can see it has a hole through it, if it doesn't go through drill it out the rest of the way. I had 2 latches, the original 90 had a hole through it, the 89 did not.
I ran 18 gauge wire through the hole, put a round crimp on connector on the end and put the round pull thing back on it tight (it acts as a pinch).
Routed the wire like the next coupel wires.
You'll need to use a fish to get the wire through the reinforcements.
Proof of concept.
ENJOY
Remove the latch.
Proof of concept.
ENJOY
Page 1 of 2 • 1, 2
Page 1 of 2
Today at 8:08 pm by gwistrup
Yesterday at 11:12 pm by Nath1142
Tue Apr 23, 2024 8:22 am by lowform
Tue Apr 23, 2024 8:12 am by lowform
Tue Apr 16, 2024 8:28 am by JW1970
Tue Apr 16, 2024 7:59 am by JW1970
Mon Apr 15, 2024 10:51 pm by Raymond-P
Sat Apr 13, 2024 4:07 am by Rob44
Thu Apr 11, 2024 11:09 am by LS982
Tue Apr 09, 2024 2:54 pm by lowform
