oil pan options
+7
Tetzuoe
944v8inDFW
Johnny Johnny
968gene
11 posters
Page 2 of 2
Page 2 of 2 • 1, 2
Re: oil pan options
The RH pan sit just about 1/4" at it's lowest point below the cross member. There are 1/2" spacers to lower the cross member though.
Pictures of the RH oil pan in place
This is the RH conversion oil pan with 1/2" spacers under the cross member. The exhaust hangs a little lower
Re: oil pan options
And with the Moroso 20140, do I also need to order the 24050 oil pump pickup as well?
Johnny Johnny- Posts : 164
Re: oil pan options
yeah, I had to, it runs along the passenger side of the pan.. so dont cut a notch in that side (I made that mistake)
Tetzuoe- Posts : 178
Re: oil pan options
JJ........"And with the Moroso 20140, do I also need to order the 24050 oil pump pickup as well?"
I modded up the Truck Pickup and rewelded it where it's intake set 1/2" above the bottom of the Moroso pan. IIRC 5.5" from the bottom of the bolck with a Carpenter's Square. Save 80-100 Bucks
Re: oil pan options
Now that I'm going with the Moroso pan and have no use for my Lingenfelter oil block, I was thinking about something like this:
I was planning on using an oil cooler anyways, and this has both the cooler and the filter relocation parts. Do you think it's dodgy?
Re: oil pan options
You might take a look at summit racing and see what they have to offer. I have bought good quality coolers for the Cobras that I build from them. Should be cheaper by the time you by the oil lines.
20140 Mod Dims
I posted the Modification dims needed for the Moroso 20140 Pan in my gallery for you guys
OEM Bolts too long
The OEM pan bolts look to be too long once the aluminum pan is swapped out for the stamped steel pan. (especially the two rear bolts) Where have you guys been sourcing the replacement bolts?
968gene- Posts : 259
OEM Bolts Too Long
I've got a question into Moroso tech. They have a stud kit that looks like it will work, but there are only 14 studs in the package..we would need 15.
Inlet/Outlet
Someone please identify which is inlet/outlet on the the Moroso Oil Pan ports.
Inlet/Outlet
Re: oil pan options
Re: oil pan options
968gene wrote:The OEM pan bolts look to be too long once the aluminum pan is swapped out for the stamped steel pan. (especially the two rear bolts) Where have you guys been sourcing the replacement bolts?
The only problem I had was with the rear two. The others bolted in and torqued down just fine. The rear two I ended up grabbing some short bolts and washers from mcmaster. I could probably send you two if need (came in a pack of 50 )
robstah- Posts : 352
Page 2 of 2 • 1, 2
Page 2 of 2
