Flasher relay buzzing
My early 944 was an electrical disaster when I started driving it. It sat for years in the weather and corrosion in the connections caused me headaches daily. So I decided to re wire the car using a universal fuse block. Using the diagrams on pelican parts I was able to make everything work properly and consistently. I have 1 issue that I can not figure out.
The relay buzzes anytime the key is in the ignition (accessory and run positions). The flasher switch has constant 12v, and the turn signals are powered when in the run position. Both the flashers and turn signals work properly, and when it is flashing the buzzing stops.
I have tried another relay, and I have double checked my wiring to verify it is exactly like the factories. Something obvious has to be wrong.
Any thoughts or ideas?
tonyorlo- Posts : 24
Re: Flasher relay buzzing
tonyorlo wrote:My early 944 was an electrical disaster when I started driving it. It sat for years in the weather and corrosion in the connections caused me headaches daily. So I decided to re wire the car using a universal fuse block. Using the diagrams on pelican parts I was able to make everything work properly and consistently. I have 1 issue that I can not figure out.
Does it sound like a key left in ignition buzzer? Or just a rapid relay click?
It stays buzzing like the door is open or the seat belt needs buckled.
Almost sounds like you have the wrong relay in the turn signals
Today at 4:44 pm by JW1970
Today at 12:39 pm by Nath1142
