New convert under way
+48
superman22x
turbobob924
RestomodCorvettes
chrenan
iamgod
944_GASM
Hotrodz of Dallas
racertomtom
sparkydog
matt889
HorizonblueDK
crowstyle
pa951
ScottM1A
Slpr948
erioshi
blown 9442
Robb Northrup
Gutterboy
bluejk09
cjbcpa
eclou
kelleysj
Insulator
skywalker01
applebit
MillsMotorsport
suboptimalfit
a951
Dan J
laptop_geek
singleslammer
52 posters
Page 4 of 31
Page 4 of 31 • 1, 2, 3, 4, 5 ... 17 ... 31
trans
Will be starting to cut out the rear floor section after x-mas to allow the vette 6 speed moch up.
kevin924kevin- Posts : 927
it begins
Well today was a good day, the floor section and rear back seat area removed. I found a C6 six speed withh 11k on it complete with carrier and torque tube. ( in Canada) Hopefully will be shipped in the next few days. I will post photos on friday of the back section. tHIS IS GOING TO BE I THINK A VERY GOOD SWAP. Seats still fit really well. I will start to mock up cage and cross supports. Should be able to build and slide in to the car. Will keep you all posted.
Another good day
Hello, had another good day in the garage. Today i did the mock up roll hoop and bottom bracing to allow the C6. I made a form fitting wood template of the structure. I will use 1.5"x 1/8 " square tube for the cross section support and 1.5" x.95 roll for the hoop. I incorperated the structure right in to the factory cross member, with a new 13" opening,will be very strong. I ran the back brace down to the shock tower location, for now a 4 point will do, but will be 6 point at the end, for now the trany area is more important. As i thought i can build the structure out of the car and it fits in very nice. Did i mention you can keep the interior in when completed. I have taken a bunch of photos, i will down load on the weekend and post. U will see in the pics that the back floor area will come out flat all the way to the cage area.Should allow for real nice cargo area.(golf clubs). I think this design will be a very nice swap option.There may be enough area left on both sides of the trany, and in front of the axles to allow a couple of aluminum fuel cells linked, it would place more weight in the middle of the car, and lower to the ground.Seats seem to fit well (pics).I think i will run the sq tube at the hump down to the floor pan and back to the rocker area, to allow a point of mount for the split torsion tube, everything should fit very nice. I cant wait for the trans to arrive, I will have the hoop bent this coming week, sq tube in stock.Next on the menu, is to strip down the torsion unit and start the cutting, HOPING to remove 12" out of the center. trans is about 10" at that point. Will see.Keep you posted. Please feel free to share your thoughts on the structure, or anything else. QUESTION what is the gap (measurement) from the top of the porche TT to the underside of the tunnel? AGAIN THANKS to everyone that has supplied info/photos to allow this process to happen.
Re: New convert under way
Excellent!
acorad- Posts : 697
fab time on the 924
[You must be registered and logged in to see this image.]://i47.se[You must be registered and logged in to see this image.]rvimg.com/u/f47[You must be registered and logged in to see this image.]/16/17/65/65/hpim9212.jpg" />[You must be registered and logged in to see this image.]i47.servimg.c[You must be registered and logged in to see this image.]om/u/f47/16/17/65/65/hpim9216.jpg" />[You must be registered and logged in to see this image.]These pics give you an over view many more pics, will add over the weekend
C5 trans
Well, trans purchaced confirmed, now the wait begins, have made great progress on the metal fab. I installed my porsche TT to get and idea. I will post pics this week. Should have hoop by end of week beginning of next week. keep you all posted.
more pics
[img][You must be registered and logged in to see this link.][You must be registered and logged in to see this image.]ervimg.com[You must be registered and logged in to see this image.]/u/f47/16/17/65/65/hpim9222.jpg[/img][img]http:[url=https://servimg.com/view/16176565/54][You must be registered and logged in to see this image.][/ur[url=https://servimg.com/view/16176565/55][You must be registered and logged in to see this image.]l]//i47.s[You must be registered and logged in to see this image.]ervimg.[You must be registered and logged in to see this image.]com/u/f47/16/17/65/65/hpim9225.jpg[/img][/url][/url] Just a few more pics of the changes.
Great work. You should be able to slide that TT right back and get to the clutch easier.
Man! That is some impressive work - and I thought I got weak in the knees cutting wheel wells
skywalker01- Posts : 477
C6trans
Ty for the praises, but there are a bunch of individuals on this form that contributed a lot of info to allow this process.With out there help this would not be possiable.The torsion tube looks as it will be a simple operation to cut and splice,I'm thinking a nice mandrel bent 3" tube, gussetted on the sides for strenght and will also allow a fastening point in the center on a bushing ( just to make sure) but i want to wait for the trans, so i can sit it in place and do the final measure up. I plan to add a cross tube above the floor line to allow a point to fasten a proper harness. There will be a tube placed at the base of the rear hoop supports ( at rear shocks) tucked down on to the frame( just below floor height) and a brace running flat from the same point out to the center of the main structure. ( more triangalation ) should make the hole area nice and stiff. I Think i can reinforce my stock gas tank support/ trans mount cross brace to allow use of the factory C6 rear mounts. Please feel free to make suggestions, the more the info the better the finished product. THE TRANS IS A C6. Thank you all.
Just outta curiosity what are you going to do for axles?
Axles
Well, i think xschop has that side of the change sorted out, chrome moly 930 joints, bigger cages, these should handle the HP, and give reliability. Just one of the fine products avaliable on this forum.
Is the bolt pattern the same on the c6 transaxle?
I believe xschop has some one looking into the info we will need.
Ya, I bet the overall length may be different too... If anyone can make them, it's him... Good luck!
C6
Thank you, i have a lot of faith in the products, designed an built on this forum. We are fortunate to have access to so much info and products.
What part of Canada are you from?
C6trans
I am in Winnipeg Manitoba the longitudanal (spelling) center of Canada. Burr
lol... ya, I bet it's cold right now... Today was only -17c haha...
C6trans
Ya today we hit +2 and the balance of the week looks good, well time to retire to the garage and get some work done, have a good night and talk soon.
C6
Well, still waiting for the trans but it is finally in route. So i have been playing with the rear quarter mods. A little more cutting and should be close. Once i have the quarter sitting proper i will take pics and post.Thses are 997TT quarters, it sure changes the look of the car, but in the right direction.
My wide body mods
[img][You must be registered and logged in to see this link.][You must be registered and logged in to see this image.]7.s[You must be registered and logged in to see this image.]ervim[You must be registered and logged in to see this image.]g.[You must be registered and logged in to see this image.]com/u/f47/16/17/65/65/hpim9230.jpg[/img[img][You must be registered and logged in to see this link.]servimg.com/u/f47/16/17/65/65/hpim9235.jpg[/img][/url]][/url] Just a few pics of my wide body conversion. Trans has landed, will get some more pics when trans is in place
C6 trans
It has landed. Pick up the trans and torque tube this am. Just waiting on the carrier to arrive, i will take some picks tonight. Any thoughts on my body mods?
Page 4 of 31
