» 85 5.3 swap
New convert under way  - Page 5 EmptyYesterday at 4:15 pm by smkn951
» low cost and available bellhousing...maybe
New convert under way  - Page 5 EmptyYesterday at 2:16 pm by Admin
» Starter issues
New convert under way  - Page 5 EmptySun Oct 18, 2020 12:48 pm by zeusrotty
» Sharkey's 944 corvette t56 swap thread
New convert under way  - Page 5 EmptyTue Oct 13, 2020 10:01 am by Myporschels
» FS: 1987 951 LS
New convert under way  - Page 5 EmptyTue Oct 13, 2020 5:41 am by carr911
» 5th gear options, Audi?
New convert under way  - Page 5 EmptyMon Oct 12, 2020 1:18 pm by acorad
» Garage queens
New convert under way  - Page 5 EmptyMon Oct 12, 2020 11:57 am by gdopnt
» Where did you find your LS1? I need one :)
New convert under way  - Page 5 EmptySun Oct 11, 2020 10:33 pm by smkn951
» 78 928 LS1 swap initiated
New convert under way  - Page 5 EmptyThu Oct 08, 2020 12:21 pm by Hey_Allen
» cv axles breaking
New convert under way  - Page 5 EmptyWed Oct 07, 2020 11:24 pm by Plucky948
October 2020
Page 5 of 31 Previous  1, 2, 3, 4, 5, 6 ... 18 ... 31  Next
New convert under way  - Page 5 Empty Re: New convert under way
Post  skywalker01 on Tue Jan 03, 2012 5:04 pm
Man! That is some impressive work - and I thought I got weak in the knees cutting wheel wells Shocked
skywalker01
skywalker01
New convert under way  - Page 5 Empty C6trans
Post  kevin924kevin on Tue Jan 03, 2012 6:08 pm
Ty for the praises, but there are a bunch of individuals on this form that contributed a lot of info to allow this process.With out there help this would not be possiable.The torsion tube looks as it will be a simple operation to cut and splice,I'm thinking a nice mandrel bent 3" tube, gussetted on the sides for strenght and will also allow a fastening point in the center on a bushing ( just to make sure) but i want to wait for the trans, so i can sit it in place and do the final measure up. I plan to add a cross tube above the floor line to allow a point to fasten a proper harness. There will be a tube placed at the base of the rear hoop supports ( at rear shocks) tucked down on to the frame( just below floor height) and a brace running flat from the same point out to the center of the main structure. ( more triangalation ) should make the hole area nice and stiff. I Think i can reinforce my stock gas tank support/ trans mount cross brace to allow use of the factory C6 rear mounts. Please feel free to make suggestions, the more the info the better the finished product. THE TRANS IS A C6. Thank you all.
Post  spence on Tue Jan 03, 2012 6:20 pm
Just outta curiosity what are you going to do for axles?
New convert under way  - Page 5 Empty Axles
Post  kevin924kevin on Tue Jan 03, 2012 6:33 pm
Well, i think xschop has that side of the change sorted out, chrome moly 930 joints, bigger cages, these should handle the HP, and give reliability. Just one of the fine products avaliable on this forum.
Post  spence on Tue Jan 03, 2012 6:51 pm
Is the bolt pattern the same on the c6 transaxle?
Post  kevin924kevin on Tue Jan 03, 2012 7:01 pm
I believe xschop has some one looking into the info we will need.
Post  spence on Tue Jan 03, 2012 7:04 pm
Ya, I bet the overall length may be different too... If anyone can make them, it's him... Good luck!
Post  kevin924kevin on Tue Jan 03, 2012 7:07 pm
Thank you, i have a lot of faith in the products, designed an built on this forum. We are fortunate to have access to so much info and products.
Post  spence on Tue Jan 03, 2012 7:08 pm
What part of Canada are you from?
Post  kevin924kevin on Tue Jan 03, 2012 7:12 pm
I am in Winnipeg Manitoba the longitudanal (spelling) center of Canada. Burr
Post  spence on Tue Jan 03, 2012 7:14 pm
lol... ya, I bet it's cold right now... Today was only -17c haha...
Post  kevin924kevin on Tue Jan 03, 2012 7:20 pm
Ya today we hit +2 and the balance of the week looks good, well time to retire to the garage and get some work done, have a good night and talk soon.
Post  kevin924kevin on Fri Jan 06, 2012 8:29 am
Well, still waiting for the trans but it is finally in route. So i have been playing with the rear quarter mods. A little more cutting and should be close. Once i have the quarter sitting proper i will take pics and post.Thses are 997TT quarters, it sure changes the look of the car, but in the right direction.
New convert under way  - Page 5 Empty My wide body mods
Post  kevin924kevin on Mon Jan 09, 2012 8:33 am
[img][You must be registered and logged in to see this link.][You must be registered and logged in to see this image.]7.s[You must be registered and logged in to see this image.]ervim[You must be registered and logged in to see this image.]g.[You must be registered and logged in to see this image.]com/u/f47/16/17/65/65/hpim9230.jpg[/img[img][You must be registered and logged in to see this link.][You must be registered and logged in to see this image.]servimg.com/u/f47/16/17/65/65/hpim9235.jpg[/img][/url]][/url] Just a few pics of my wide body conversion. Trans has landed, will get some more pics when trans is in place
New convert under way  - Page 5 Empty C6 trans
Post  kevin924kevin on Mon Jan 09, 2012 1:22 pm
It has landed. Pick up the trans and torque tube this am. Just waiting on the carrier to arrive, i will take some picks tonight. Any thoughts on my body mods?
Post  xschop on Mon Jan 09, 2012 4:35 pm
That's sickening...in a good way. Have you got a chance to search an outter stub axle conversion yet? It's the key to using 930 CV's and off-the-shelf axles. I know that the early 944's have different (low #) splines than the later outer shafts and 930 stub axles exist.
New convert under way  - Page 5 Empty trans
Post  kevin924kevin on Mon Jan 09, 2012 4:38 pm
not yet, but will be looking into that portion next. any thoughts on that issue?
Post  xschop on Mon Jan 09, 2012 4:41 pm
I remember seeing a VW with early 944 trailing arms converted to 930 CV's using a commercial stub axle. Also Paul (948) posted a conversion stub axle IIRC.
Post  Rich L. on Mon Jan 09, 2012 5:16 pm
I have just now clued-into the yellow 911 and the red 924 being the same car. "Sick" is right. People are not going to know what to make of a front-v8-engined 911. Fun!
Post  xschop on Mon Jan 09, 2012 5:26 pm
A perfect balanced All GM 911 Razz
New convert under way  - Page 5 Empty 924C6
Post  kevin924kevin on Mon Jan 09, 2012 8:16 pm
I can't wait to start the install of the trans. Have to do a little reassembly to the trans, they took some parts off and sent seperated to meet the weight issues on the shipping side, but looks good. I think trim two stubs out the side and that area will be where the torsion tube will cross, which means about an 11" removel out of the center of the torsion unit + or -. I have pulled the torsion bars out of my torsion unit, when cut it will remove the splinded section from the middle and weight. The trans without carrier was 105 pounds according to shipping docs. The TT tube is definetly lighter than our stock TT. will send pics.
Post  xschop on Mon Jan 09, 2012 9:56 pm
While you are at it take detailed pics of how the front input shaft removes and it's dimensions. I always thought it would be trick to mod one to fit the front of the 948 swap. And I'm pretty sure the T1 to 930 stub shaft conversion that EMPI sells will fit perfectly in the EARLY trailing arms as those stubs shafts are also longer than the late stub shafts.
Post  kevin924kevin on Wed Jan 11, 2012 8:21 am
[img]htt[url=https://servimg.com/view/16176565/66][You must be registered and logged in to see this image.]p:[You must be registered and logged in to see this image.][/u[url=https://servimg.com/view/16176565/68][You must be registered and logged in to see this image.]rl]//i4[You must be registered and logged in to see this image.]7.servimg[You must be registered and logged in to see this image.][/u[url=https://servimg.com/view/16176565/71][You must be registered and logged in to see this image.]rl].com/u/f47/16/17/65/65/hpim9237.jpg[/img][/url]
Post  kevin924kevin on Wed Jan 11, 2012 8:28 am
Well here are a few pics of the trans. It would appear that the trans will fit quit nicely between the trialing arms for the rear suspension. I am going to start test fitting torque tube. From the measurements i have taken, it looks like the vette shifter is only an 1 1/2 plus or minus farther forward than the stock porsche local, will update with further pics. I want to set the torsion T back in and set trans to make sure things will work before i cut the torsion tube. But i think this mod should work very well.
Post  Insulator on Sat Jan 14, 2012 10:56 pm
You've got mad fab skills. What a Face
Just hoping my fab work turns out as well. Just starting mine with my Dad. Pics will follow soon. I don't know how I could do it without you guys who have been there and done that
Thanks again
Insulator
