MPG Gauge,
MPG Gauge,
Is there an easy way to stop the stupid thing from moving? where does it get it's signal from?
Wild Bill- Posts : 121
Re: MPG Gauge,
The signal originates from the hall sensor in the speedo. Then it is combined with data in the ECM and an output signal operated the MPG gauge.
If it was disconnected I would expect it would not move. But if the wired are still there between it and the hall sensor maybe transients are causing it.
BTW, I am going to use the hall sensor in the speedo for VSS signal.
v8carreragts- Posts : 332
