Bracketry Trickery
Bracketry Trickery
Hi
I have the Corvette 95 LT1 and will be fitting it into a 944 turbo (951). What brackets do I need for the ancilliaries etc. I will be using power steering and probably a/c at some point. I belive the F-body Camaro brackets might be the ones to ensure that the right hood clearance is obtained? Cam someone who has done this please advise?
Re: Bracketry Trickery
If you end up deciding to use the camaro bracket. I have one from my engine I'm not going to be using along with it's accesories. I would be willing to sell it all together if you're interested.
Oh, you're from the UK. Ya, that may be costly....
Yes. This is the bracket you need. Although, it will need to be modified a bit.I belive the F-body Camaro brackets might be the ones to ensure that the right hood clearance is obtained?
This is a picture of my LT1 bracket with modification. Simply, you have to shorten the alternator tower upright a bit. You can either cut and bolt it or have it welded.
That's brilliant - many thanks for the information and picture.
Can you also advise as to whether the Corvette p/s pump and a/c pump will fit on the other side of the engine using a camaro accessory bracket?
Q
Q
