» Headers, headers, HEADERS!
» Electric brakes
Bracketry Trickery
Bracketry Trickery
Post  quarterflash on Tue Aug 10, 2010 5:45 am
Hi
I have the Corvette 95 LT1 and will be fitting it into a 944 turbo (951). What brackets do I need for the ancilliaries etc. I will be using power steering and probably a/c at some point. I belive the F-body Camaro brackets might be the ones to ensure that the right hood clearance is obtained? Cam someone who has done this please advise?
quarterflash
http://porschevy.co.uk/
Re: Bracketry Trickery
Post  spence on Tue Aug 10, 2010 6:36 am
If you end up deciding to use the camaro bracket. I have one from my engine I'm not going to be using along with it's accesories. I would be willing to sell it all together if you're interested.
Post  quarterflash on Tue Aug 10, 2010 6:45 am
Hi Spence
I will bear that in mind although postage to the UK mght be costly?
Q
quarterflash
Post  spence on Tue Aug 10, 2010 6:50 am
Oh, you're from the UK. Ya, that may be costly....
Post  944-LT1 on Tue Aug 10, 2010 9:05 am
Yes. This is the bracket you need. Although, it will need to be modified a bit.
This is a picture of my LT1 bracket with modification. Simply, you have to shorten the alternator tower upright a bit. You can either cut and bolt it or have it welded.
Post  quarterflash on Mon Aug 16, 2010 6:40 am
That's brilliant - many thanks for the information and picture.
Can you also advise as to whether the Corvette p/s pump and a/c pump will fit on the other side of the engine using a camaro accessory bracket?
Q
quarterflash
