Metric or SAE hardware?
Do LT motors have metric or SAE hardware?
v2rocket- Posts : 121
Re: Metric or SAE hardware?
A bit of a tricky answer to this.... Since the LT engines use basically 1970's GM patterns and design, they (especially the intake) use SAE. However, since the late 1970's (1978/79), GM has converted to strictly metric fasteners.
Because of the similarities of 1970 LT engines and modern 1990 LT engines, many bolts are SAE. Regardless, LT engines of 96 and 97 were all switched to metric. So, in short, LT engines as well as other GM engines that have not been re-designed since 78/79 use SAE up to 1996 but none other than metric on anything onwards. ANYTHING that was designed/altered by GM after 78/79 use metric.
My 95 LT1 has metric up top (Intake and such) and SAE on bottom (oil pan bolts, head bolts). Unlesss it was some great conspiracy that 14mm socket fit better than the SAE alternative.
Dawgz83948- Posts : 603
