» ecotec swap
Yesterday at 3:53 pm by Hotrodz of Dallas
» New 944 widebody & aero
» Wilwood MC on it's side
» V8 Conversion Parts
» Fuel pump options
» Poly engine mounts melted
» JP's LS1 Conversion
March 2018
Metric or SAE hardware?
Post  v2rocket on Tue Jul 06, 2010 12:06 am
Do LT motors have metric or SAE hardware?
Re: Metric or SAE hardware?
Post  944-LT1 on Tue Jul 06, 2010 12:39 am
A bit of a tricky answer to this.... Since the LT engines use basically 1970's GM patterns and design, they (especially the intake) use SAE. However, since the late 1970's (1978/79), GM has converted to strictly metric fasteners.
Because of the similarities of 1970 LT engines and modern 1990 LT engines, many bolts are SAE. Regardless, LT engines of 96 and 97 were all switched to metric. So, in short, LT engines as well as other GM engines that have not been re-designed since 78/79 use SAE up to 1996 but none other than metric on anything onwards. ANYTHING that was designed/altered by GM after 78/79 use metric.
Post  Dawgz83948 on Tue Jul 06, 2010 10:49 am
My 95 LT1 has metric up top (Intake and such) and SAE on bottom (oil pan bolts, head bolts). Unlesss it was some great conspiracy that 14mm socket fit better than the SAE alternative.
