944Hybrids
Welcome to our forum.
» Pacific Raceways near Seattle
Today at 7:26 am by Lemming
» HELP . . . Electrical gremlin
Today at 12:01 am by Rich L.
» Rich's LS powered 944 track car
Yesterday at 8:59 pm by Lemming
» First Time Swap 85 Porsche 944 to LS6
Yesterday at 7:03 pm by kjducati
» Oil and steering cooler options
Yesterday at 6:11 pm by docwyte
» selling conversion parts due to new baby
Yesterday at 4:29 pm by zeusrotty
» Strut brace?
Mon May 14, 2012 5:38 pm by fliermike45
Mon May 14, 2012 1:56 pm by epsylon9mm
» building a 1983 948 on a budget - pointers?
Mon May 14, 2012 7:19 am by Admin
» To " badge or not to badge "
Sun May 13, 2012 5:01 pm by 944-LT1
May 2012
78910111213
14151617181920
21222324252627
28293031
LT1 mounts for engine hoist?
Post  subterfuge on Thu Apr 22, 2010 2:19 pm
Hey guys, I have my engine at work, now I have a hoist. I think you can bolt mounts for a chain somewhere on the engine, but a quick google search didn't pull anything up. Anybody know where I can get some, and where I can mount them to lift the engine?
subterfuge
Re: LT1 mounts for engine hoist?
Post  subterfuge on Thu Apr 22, 2010 4:58 pm
For example, here are bluehellfire666's pics, are these just home made plates?
subterfuge
Post  bluehellfire666 on Thu Apr 22, 2010 5:21 pm
yes, these are home made plates. Barry, the guy that helped with with this build took some plates of metal and blew some holes in them with a torch. this was the easiest and quickest seemingly safe solution that we could think of. I guess if you wanted to you might be able to make some plates that bolted to the top holes where the bellhousing bolts go...and then find something on the front that would balance it out, but it seemed to me that there aren't a whole ton of options when trying to find places to lift from.
Another option is to get solid motor mounts (the actual bent plate that attaches to the engine) put a bolt through them and attach there, but you may have trouble balance the engine front to rear.
hope this helps!
bluehellfire666
Post  subterfuge on Thu Apr 22, 2010 5:25 pm
Yeah it does, actually after seeing your pics, I did find a few references to using the holes on the side of the heads through various different means to lift, so that is what I'll be doing. Thanks-
subterfuge
Post  subterfuge on Thu Apr 22, 2010 5:41 pm
Hey, you don't happen to know what size bolts go in the side of the heads do you?
subterfuge
Post  bluehellfire666 on Fri Apr 23, 2010 9:52 am
hmmmm, off the top of my head i can't remember, but i'm pretty sure it's the same as most of the bolts on the block...you can probably steal one from somewhere else and test the thread pattern
bluehellfire666
Post  subterfuge on Fri Apr 23, 2010 1:26 pm
Looks like it is a 3/8, the 5/16 are too small.
subterfuge
