Skywalker001 Build - Got my new shoes
+19
laptop_geek
v8944
Ender751
MN944S
Luke714
HotShoe
DVC
modenas
stu wright
skywalker01
23 posters
Page 2 of 4
Page 2 of 4 • 1, 2, 3, 4
Phatty
""""now I need to find some decent locks - any suggestions??""""
How bout a G-lock.... model 27 to be exact....
Seriously nice look going on there Sky
Re: Skywalker001 Build - Got my new shoes
Looks Great! Love lots of rubber! Did you actually find 5x130 bolt pattern or did you use adapters/changed the hubs?
Luke714- Posts : 441
@Hotshoe - Thanks for the compliment! Trying to get final color on by Saturday.
Here are the specs on the rims:
Front - WORK MEISTERS S1 3P 18X11 -8
Rear - WORK MEISTER S1 3P 18X12 -20
Just a warning! The front 18s at this size do rub the wheel well about a quarter turn before lock. Don't know if its that much of an issue yet.....
skywalker01- Posts : 477
@XSCHOP - Thanks for the recommendation! Need something that will fit on the wheels though!
@Luke - Thanks for the compliments! The wheels are custom made with that lug pattern - for the price I paid, they'd better fit without adapters!
Wow, looks great! That's going to be a beautiful car when you're done
Well.....what color!?! Im thinking, with those rims and that body...should be guards red!
If you have a manual rack (and maybe with the PS rack) you can adjust the locks on the output shafts of the rack to stop before rubbing. My manual rack has one on each side. Not sure if you can do this but may be worth looking into. .....Or, cut up the spot its rubbing on!
Sorry 944-LT1, for some reason I have forgotten how to quote. Thanks for the information on the locks - I was thinking I could adjust camber and also take care of the issue, but the solution you provide is probably the better one. As for color, you'll have to wait with the rest of the world - but rest assured, it will be something that will definitely make the car stand out (at least in my opinion )
Just no hot pink, ok?
Dawgz83948- Posts : 603
I was actually thinking about a TMNT theme!!
Thanks Porch! You had a hand in my car too (when you had my header).
Are you at all worried about the transaxle or the axles with all that yummy power and rubber? You're using an NA tranny, right? Maybe I'm recalling the wrong car, but I thought that's what you said you were running in a previous thread.
Yes, I am worried.....to a degree. I'm not planning on launching alot (initially), so the transaxle should be okay. After I get some seat time in the car, I plan on replacing the heads/cam - at that time, I think I'll start looking at a new rear end.
Green??? ..... RED!!!!!!!
The moment has arrived
It's all been leading up to this!! Blast away guys!!
As Grady (from Sanford & Son) would say...
Wicked.
Pat, that will dominate the Castrol Showdown this time, no doubt...Grady wrote:"Good Goobledey Goop, Fred!"
Wicked.
gt1scca- Posts : 795
Thanks! While I was trailering it back, I got some pretty hard stares - the desired effect!!
It's missing the Grand Sport stripes, but I will take care of that when I get back from my business trip. All I know is I couldn't have gotten this far without the support from the guys on this board!
I don't know if they're have the Castrol Challenge this year - but I am seriously considering Bullrun.
If you still want some decals let me know...
I haven't forgotten, I just got "side-tracked".
I'm actually looking for a 'subdued', gunmetal crest 'decal'.....
I think I can come up with something...
Give me a day or two.
I think I just wet myself.
Not normally a fan of the big pedestal mounted wings, but with the rest of the car, by god it works.
MN944S- Posts : 32
beautiful work! What lovely aggressive lines, the flares look good.
Luke/MN944S - Thanks for the feedback! With the wing, I was afraid of coming of too ricer'ish. But with the satin black paint and the large offsets, the wing gives a certain level of aggressiveness to the rest of the car (and it's functional too !). I think had I stayed with the Millennium Yellow with the new hatch, I would have looked like a rolling lemon.
This look says: "Lord Vader, your ride has arrived"
what was your reason for going with the notch back instead of the stock fast back kinda look?
Was looking for something different, plus all of that glass back there - I really didn't like it. Lesson learned though through the process of buying body parts: Don't buy cheap! While the "plan A" (gt-racing.com) hatch was significantly cheaper (and lower quality), the one you see now (allporscheracing.com) was originally my first choice - but I said it was too expensive.
Page 2 of 4
Yesterday at 8:32 am by Rob44
