Can anyone identify a Harmonic Balancer?
Can anyone identify?
Has the following numbers:
NH1480 F73 2605
NH1480 F73 2605
Re: Can anyone identify a Harmonic Balancer?
Its hard to see but theres a GM part number on the outer rim of the balancers between the two belt grooves. Its quite faint but its there....if its a GM part.
Harmonic Ballancer
Have looked all over but could not find any additional numbers.
Must assume that it is an aftermarket unit.
If its been painted, its possible its covered. But yeah it could be aftermarket. Got a pic? Heres mine from a 2009 LS. You can just make out the numbers.
This is an LS2 balancer stamped with NH1480. If it looks like this one, its from an LS2 vette. It could also be from an LS6 though.
Harmonic Balancer
Thanks guys for your inputs.
I managed to contact the guy who sold me the LS1 that was removed from a C5 Vette. The HB he supplied was a replacement (don't know what happened to the original). He confirmed that the HB came from Pace Performance with a GM part number Harmonic Balancer 12553118, the pace website lists this for F-Car and GTO applications. Seems he did me a favour as I am changing over to F-Car accessories.
Thank you all again.
Excellent.
BTW.....just me and you here.
Correction
Thanks guy!
Now I have to fix the Power Steering pump problem.
