poor man porsche
+6
ffmedic
modenas
10 posters
Page 2 of 2
Page 2 of 2 • 1, 2
Do you like my car and the conversion im doing?
Re: poor man porsche
what is SW. Power? i dont have a PCM and a pink wire??
number 5 on the 14 pin list, we dont need the the fuel pump relay?
KEEP in mind that is SBC NOT LS1!!!
modenas- Posts : 285
i need to know about driver side header
You need a bypass type regulator to use the stock pump with a carb. This will regulate to the pressure you need and bypass the balance of the fuel back to the gas tank.
The problem with just using a regulator is that you basically dead head the pump and it overheats the motor. The fuel system of all FI cars use a bypass on the regulator for this reason. Even the cars like Chrysler that only hace one fuel line fron the tank. These have a regulating device that bypasses at the outlet of the pump inside the tank. The FI pump motor is cooled by the gas flowing through it.
v8carreragts- Posts : 332
Simple fix to your fuel pump problem.
Take out the porsche stock fuel pump located under the cover of your gas tank rear passanger side , put in a electric fuel pump with a regulator that is rated for your carbed engine or put in a line instead of the porsche fuel pump and use the mechanical pump on your engine. Stick with the easy solution.
You'll bypass any problems with the porsche pump overheating.
Shouldn't take more then maybe 45 min and that is probabley estimating abit on the long side.
ffmedic- Posts : 103
o lala me like the v8 in my porsche, just got done doing the motor into the car, she a beauty!, pics later
well figure i do an update, i have the right header in and haveing trouble finding one for the left, everything i got hits the steering shaft
i have an auto matic version of the 944 i used original porsche bellhousing n made an adapter plate out of 3/8 steel plate .i took the original porsche flywheel welded the holes and redrilled the holes 4 sbc .it still uses orig. porsche starter.fidanzza makes flywheels for various applications including porsche 944 could probaly make a flywheel drilled with sbc bolt pattern
stu wright- Posts : 312
on left side exsaust i made my own header that is two piece and clears steering shaft pass sides uses 85-90 camaro
Hey modenas,
These will work also with a small amount of exhaust tubing work...
Patriot H8052 Tight Tuck Headers
gt1scca- Posts : 795
exhaust solved!! THANKS to xschop i turned my hugger header upside down ( im cutting the hood for carb so might as well make it for the exhaust also) and use alot of flex pipe to run the exhaust, will update and take pics later
"Dig through the ditches, And burn through the witches
I slam in the back of my Dragula..."
here a few pics, it dark but you get the hint
driver header
passenger header
here you can the space between the header and shaft
(sorry guys) it all dark i know, my bad, but it frezzing during the day so im gonna try to take pics when it warm
driver header
passenger header
electric water pump installed, headers doing tomorrow due to weather today, and brake plate installed, but the master is not because we need the room to get to the headers. got a single pulley for the crank to run the alt. dual electric fans installed. what else to say?
Hi! What are you going to do for a master cyl?
As far as fuel pressure regulator this IMO is the the best for the price return type regulator on the market! Mallory 4309, [You must be registered and logged in to see this link.] Used one on my 489 BBC on my airboat. Planning on picking up another one for my 944/SBC!
Hot Links are nice but copy/paste works! Bill
Wild Bill- Posts : 121
master cylinder has a plate made by xschop and it not installed becuase i need for room, fuel reg im using the stock on and putting a reg for the carb and using an electric fuel pump
i need admin please, move this to the lsx thread, im moving up in the conversion world!
got pics for you dirty hybrids out there,
got a 5.3 all of it but no pcm or harness, for $$, ultra cheap! lower that what it should have been, came with a mild cam, 706 heads, already had 2312 headers, 5.3 intake with injectors and all, even a 90MM throttle body, brand new!!!, fly by wire, guy didnt want it. truck oil pan, no pickup tube, bu for the most part it is there. just a few things not there but i dont care, cause it was cheap and came with goodies!
well heres a pic of the 2312 headers (driver side only) on a head
So did you just chop #7 off and move it over to #1 spot (flange and all?)
That actually looks pretty good if you did do it that way......props kid
thanks and yes that what i did, cut the number 7 tube and moved all over 1 and used other parts from another to fill in the rest, look at the the first bend and that the rest of #7 and the short straight and the j pipe are from a old sbc header i didnt like
bump for fliermike, look at page 3 please sir,
Thanks for the pointer.
I see you did it differently to another guys pics. Your method keeps the new long pipe
closer to the flange.
Check my gallery, you want to make sure #1 is tucked as close as possible to #7 as it curves around. My rear driver's head is only 3/8" away from firewall and #1 is about 1 3/4" from firewall as it curves back around......The V8 trans mount (-5/8" Aft) puts it there and #3 clears the steering shaft alot more now.
Page 2 of 2 • 1, 2
Page 2 of 2
